Werner(at)keiper-koerdorf Guest
Posted: Tue Aug 29, 2006 12:38 pm Post subject: AW: AW: Heavily Corroded Wing Lift Struts |
José,
I mean that I have a modell III with modell III wing lift struts. These wing
lift struts are modified. We welded in stronger tubes.
I think that the size of modell II wing lift struts are the same on modell 3
and so you could use them for both models.
I will make on the weekend some measures.
Talk again
Werner
-----Ursprüngliche Nachricht-----
Von: owner-kitfox-list-server(at)matronics.com
[mailto:owner-kitfox-list-server(at)matronics.com] Im Auftrag von Jose M. Toro
Gesendet: Dienstag, 29. August 2006 20:45
An: kitfox-list(at)matronics.com
Betreff: Re: AW: Heavily Corroded Wing Lift Struts
--> <jose_m_toro(at)yahoo.com>
Werner:
Do you mean that you installed Model IV wing lift struts to model III
planes? Model II and model II wings are the same.
I will appreciate if you send the measures. In addition to the measure of
the two main tubes, I need the measure between the end of both tubes.
Thanks!
José
--- Werner Keiper <Werner(at)keiper-koerdorf.de> wrote:
<Werner(at)Keiper-Koerdorf.de>
Hi José,
I have a Kitfox III and I am pretty sure they are the same than on
Kitfox II.
In Germany we had to make them stronger because some testing showed
that they were not strong enough and it was a weak point.
Country regulation
asked for it.
So we replaced them with bigger tubes but they have the original
lenght. If you want I can meshure them and mail.
Have a nice day
Werner Keiper
jose_m_toro(at)yahoo.com Guest
Posted: Tue Aug 29, 2006 5:34 pm Post subject: AW: AW: Heavily Corroded Wing Lift Struts |
Thanks Werner!
José,
tubes.
Talk again
Werner
Lift Struts
Werner:
struts to model III
end of both tubes.
Thanks!
José
> Hi José,
the same than on
> Kitfox II.
some testing showed
point.
> Country regulation
> asked for it.
have the original
> Have a nice day
> Werner Keiper
browse
Subscriptions page,
FAQ,
Web Forums!
Admin.
