Deems Davis
Posted: Wed Aug 23, 2006 5:41 pm Post subject: "Paddle Type" Flap position switch? |
I've searched in vain for a flap position switch which has a wide broad
flat paddle for the toggle, similar to what Cessna uses. anybody know
where you can pick one of the up?
Deems Davis # 406
Fuse/Finishing/Panel
http://deemsrv10.com/
brian-av(at)lloyd.com Guest
Posted: Wed Aug 23, 2006 6:18 pm Post subject: "Paddle Type" Flap position switch? |
On Aug 23, 2006, at 6:40 PM, Deems Davis wrote:
<deemsdavis(at)cox.net>
broad flat paddle for the toggle, similar to what Cessna uses.
anybody know where you can pick one of the up?
Make a paddle out of wood and epoxy it to a standard spring-return-to-
center toggle switch.
Brian Lloyd 361 Catterline Way
brian HYPHEN av AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
nuckollsr(at)cox.net Guest
Posted: Thu Aug 24, 2006 3:44 am Post subject: "Paddle Type" Flap position switch? |
At 06:40 PM 8/23/2006 -0700, you wrote:
See:
http://www.aeroelectric.com/Pictures/Switches/FLAPS3.JPG
http://www.aeroelectric.com/Pictures/Switches/FLAPS2.JPG
http://www.aeroelectric.com/Pictures/Switches/FLAPS1.JPG
I could give you a part number for the switch used on
Bonanzas but you'd have to mortgage the dog to afford
it. Best you consider the DIY project.
< with experiment. >
< --Lawrence M. Krauss >
sam.marlow
Posted: Thu Aug 24, 2006 6:40 am Post subject: "Paddle Type" Flap position switch? |
Gulf Coast Avionics in Florida.
<nuckollsr(at)cox.net>
See:
LarryRosen
Posted: Tue Aug 29, 2006 6:07 pm Post subject: "Paddle Type" Flap position switch? |
Avionics Systems has one. Quite pricey at $90 each. See it here
<http://www.avionikits.com/>.
Or maybe ebay. Here was a Cessna 150 switch that sold for $9.
<http://cgi.ebay.com/ebaymotors/Cessna150-Flap-Switch_W0QQitemZ190020853902QQcmdZViewItem>
Larry Rosen
RV10 #356
Deems Davis wrote:
broad flat paddle for the toggle, similar to what Cessna uses. anybody
Deems Davis # 406
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Posted: Wed Aug 30, 2006 5:54 am Post subject: "Paddle Type" Flap position switch? |
At 10:08 PM 8/29/2006 -0400, you wrote:
Larry Rosen
RV10 #356
Tried to check this out but it seems to have been removed
from Ebay's listings. Be cautious of "Cessna flap switch"
listings. Some airplanes do use a switch modified to add
the "flap" shape to the toggle. Other Cessna flap "switches"
are really an assembly of flap handle, microswitches and
a moveable mounting plate for switches that is driven by
a Bowden cable attached to flaps. This is a rudimentary
servo-system developed at Cessna for a set-it-and-forget-it
style flap control and is probably not well suited to most
OBAM aircraft projects. Although I'll have to admit that
the idea was pretty clever!
