roncarolnikko(at)hotmail. Guest
Posted: Sat Jan 21, 2006 11:04 am Post subject: fabric temp/ paint |
What temps have been used to shrink the fabric? I could not bring myself to
go 350 on the fuselage as it was starting to deform the longerons. now I am
ready for final shrinking on the tail group and want it as tight as
possible.
I used almost one gallon of polybrush on fuselage, and almost as much
polyspray. The white however covered well with the first coat and the
second coat was a formality. barely over a half gallon. Is there any
advantage to more color? I have HVLP but used my old bottom feeder for this
as I have more experience with the older style. Not a technique for
beginers, but on autos I pull the needle way back for lots of paint, stay
close and move really fast. You can give another fast pass if needed or
move away if it went on heavy. On single stage paints this allows
completing the coat and tying in the wet edge at the starting point. May
not be needed with polytone, but did it by habit. Perhaps this why it
covered so well. Ron NB Or
Jim Shumaker
Posted: Sat Jan 21, 2006 11:30 am Post subject: fabric temp/ paint |
Ron
250 degrees F.
More paint is more weight. Do you want to fly well or show well? One of the tricks that was employed with the early kitfoxes was a very thin paint coat to save weight.
Jim Shumaker
possible.
_________________ Jim Shumaker |
rjdaugh(at)rapidnet.com Guest
Posted: Sat Jan 21, 2006 12:13 pm Post subject: fabric temp/ paint |
300F most places. 275 F in some places.
350F is too high for our foxes. And be sure your iron calibration is
accurate.
Randy
aldaniels(at)fmtc.com Guest
Posted: Sat Jan 21, 2006 2:15 pm Post subject: fabric temp/ paint |
On the 5,6,7 I use 325/350 in most places. On cold days the fabric seems
a little loose when I didn't fully shrink. The trailing edge of the wing
seems to be the place you have to watch. The Poly system is dead simple,
but there are a few tricks. Were in Oregon are you, I am in eastern Oregon.
accurate.
Randy
Lynn Matteson
Posted: Sat Jan 21, 2006 2:29 pm Post subject: fabric temp/ paint |
Did you reinforce the trailing edge of the wing with 3/8" aluminum
tubing per the later Classic IV manual? I did and I used 310F for all
my shrinking.
Lynn
On Saturday, January 21, 2006, at 05:15 PM, Alan & Linda Daniels wrote:
Quote: |
<aldaniels(at)fmtc.com>
seems
wing
simple,
Oregon.
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Posted: Sat Jan 21, 2006 2:30 pm Post subject: fabric temp/ paint |
Alan I am in North Bend (oth) next to Coos Bay. Ron NB Or
Quote: | From: Alan & Linda Daniels <aldaniels(at)fmtc.com>
Subject: Re: fabric temp/ paint
Date: Sat, 21 Jan 2006 15:15:15 -0700
On the road to retirement? Check out MSN Life Events for advice on how to
get there! http://lifeevents.msn.com/category.aspx?cid=Retirement
Brett Walmsley
Posted: Sat Jan 21, 2006 5:31 pm Post subject: fabric temp/ paint |
I went to 350 everywhere.
I also put stiffeners in trailing edge of wing.
_________________ Brett
Model IV 1200/912UL |
Posted: Mon Jan 23, 2006 9:33 am Post subject: fabric temp/ paint |
Lynn,
No, I didn't. I am pretty sure that the series 5 manual doesn't call for.
Al (see below) uses higher temperatures and does say to watch the trailing
edge of the wing. I haven't noticed any loosening fabric though.
Randy
Lynn Matteson
Posted: Mon Jan 23, 2006 8:03 pm Post subject: fabric temp/ paint |
Randy-
You probably won't see the loosening of the fabric, just a "scalloped"
look to the trailing edge, if viewed from a low angle, say, from the
tip in to the root. It's one of those things that wouldn't be noticed
normally, and I wouldn't have thought about it if I hadn't seen it in
the later Classic IV manual.
Lynn
On Monday, January 23, 2006, at 12:32 PM, Randy Daughenbaugh wrote:
Quote: |
<rjdaugh(at)rapidnet.com>
Lynn,
for.
trailing
Randy
N369LM |
smokey_bear_40220(at)yaho Guest
Posted: Mon Jan 23, 2006 8:45 pm Post subject: fabric temp/ paint |
I was advised to stiffen the trailing edge on my 5 and
I am glad I did. One person ran diagonals from the
ribs to the center of the trailing edge between the
ribs. Wish I did that. It only takes a little AL or
plywood to do it. Very light for the gain.
I did as the other person advised and sprayed
expanding foam into the trailing edge to keep it from
buckling easily. I like the extra stiffness, but both
methods would have been better.
I kept my heat to 300 except over the tanks where I
went to 315. Much more temp and I would worry about
the false ribs snapping too.
Kurt S. S-5 w/70 hrs
--- Lynn Matteson <lynnmatt(at)jps.net> wrote:
just a "scalloped" look to the trailing edge, if
viewed from a
wouldn't be noticed normally, and I wouldn't have
thought
Quote: | about it if I hadn't seen it in the later Classic IV
manual.
Quote: |
Lynn
Daughenbaugh wrote:
Daughenbaugh"
> Lynn,
say to watch the trailing edge of the wing.
> Randy
