Lee Logan
Posted: Wed Aug 30, 2006 7:47 am Post subject: AeroElectric-List Digest: 24 Msgs - 08/29/06 |
Guys: I am experimenting with a home grown moving map display system based on a 12v mini-PC and 12v LCD display. I plan to use one of the commercially available navigation software packages and an input from my GPS to drive it.
Question: Any experience with operating systems in this environment? I am aware of the altitude issues with hard drives but have not been privy to any operating system discussions. One popular software package comes ported on either Windows CE or Windows XPHome. I'm told that XP Home is more robust and less crash prone but that it routinely swaps files with its memory which means (I had never heard this one before) that it will "wear out" a flash card used as a solid state memory in a certain number of swap operations. For that reason, I was advised to go with a ruggedized HD and XP Home, not with a flash card and CE as I was originally planning.
Any experience and/or comments on this challenge?
kayce33(at)earthlink.net Guest
Posted: Wed Aug 30, 2006 11:04 am Post subject: AeroElectric-List Digest: 24 Msgs - 08/29/06 |
Hi Lee,
I've been thinking along the same lines, but as far as the ruggedized Hard Drive, there are solid state hard drives out there for use above 10,000 ft. try this URL:
http://www.bitmicro.com/products_edisk_6U_vme_scsiw.php
There are others, you might want to Google SS hd's to see what's out there.
Harold..RV9A fuselage
ainut(at)hiwaay.net Guest
Posted: Wed Aug 30, 2006 12:32 pm Post subject: AeroElectric-List Digest: 24 Msgs - 08/29/06 |
Lee, I'd rather trust my life to Linux or QNX, whether embedded or
standard, than any Microsoft product. I've been playing with computers
and making a living at it since 1977, if that helps my bona fides .
There is a learning curve to the UNIX clones, but there will also be for
a Windows embedded type system.
I'm also working on a homegrown unit (taking me lots of time) and have
yet to decide which soluiton to use. It will partly be driven by which
computer hardware I end up with, which is wholly driven by the graphics
power available on the embedded unit. However, for the trials and
software validation, I'll be using an ordinary laptop.
David M.
Lee Logan wrote:
| Quote: | Guys: I am experimenting with a home grown moving map display system
my GPS to drive it.
mitch(at)skybound.com Guest
Posted: Wed Aug 30, 2006 2:06 pm Post subject: AeroElectric-List Digest: 24 Msgs - 08/29/06 |
If I was working on a primary display ("trust my life") I'd consider
going the painful and expensive QNX route or something similar. For
secondary displays like moving maps, NT embedded is more than
sufficient. I helped develop moving map software at a company that made
avionics based on NT embedded, and believe me reliability of the OS was
never a problem. Remember, you're talking about a subset of the NT
modules (using only what you need), on a *closed* system (no end users
downloading software and viruses), and only being turned on for a couple
hours at a time and then turned off. You've got hardware and software
watchdogs, the ability to write protect whole volumes, and the control
to turn off paging. You may not want to discount it in your normal
Windows bashing, but I know it's easy to do.
Mitch Faatz RV-6A Finishing Kit Auburn, CA
David M. wrote:
computers and making a living at it since 1977, if that helps my bona
fides . There is a learning curve to the UNIX clones, but there
will also be for a Windows embedded type system.
which computer hardware I end up with, which is wholly driven by the
graphics power available on the embedded unit. However, for the
trials and software validation, I'll be using an ordinary laptop.
David M.
> my GPS to drive it.
Posted: Wed Aug 30, 2006 6:52 pm Post subject: AeroElectric-List Digest: 24 Msgs - 08/29/06 |
QNX has a free version. Of course, Linux is free for the download,
too. Just to keep the record straight.
David M.
Mitchell Faatz wrote:
<mitch(at)skybound.com>
made avionics based on NT embedded, and believe me reliability of the
OS was never a problem. Remember, you're talking about a subset of
the NT modules (using only what you need), on a *closed* system (no
end users downloading software and viruses), and only being turned on
for a couple hours at a time and then turned off. You've got hardware
and software watchdogs, the ability to write protect whole volumes,
and the control to turn off paging. You may not want to discount it
in your normal Windows bashing, but I know it's easy to do.
> have yet to decide which soluiton to use. It will partly be driven
> by which computer hardware I end up with, which is wholly driven by
> the graphics power available on the embedded unit. However, for the
> David M.
>> the commercially available navigation<<<snip>>>
