bakerocb
Posted: Wed Aug 30, 2006 2:22 pm Post subject: SlickSTART Bulletin SB1-06 |
8/30/2006
Hello Fellow Builders with Unison SlickSTART Ignition Boosters, Unison has
just published SB1-06 which calls for removal of pin 2 from the unit and the
associated wiring within 20 flight hours or at the next scheduled
maintenance, whichever is sooner.
Pin 2 is the pin that gets connected to the non boosted magneto (usually the
right one) P lead stud. During cranking this connection automatically
grounds out the non boosted magneto so that it cannot prematurely fire and
cause kickback.
Once this modification has been made to the SlickSTART unit one must ensure
that the aircraft magneto / ignition switching system is such that the non
boosted magneto is grounded out during cranking by the switching system.##
Unison is directing this change because the pin 2 connection to the non
boosted magneto "potentially compromises the redundancy of the ignition
system".
Shoot me an email if you have questions.
OC -- The best investment we will ever make is in gathering knowledge.
## PS: My installation has separate switches for each magneto. I always
cranked with the right magneto switch turned OFF (grounded out) just to
doubly ensure that the right magneto could not fire prematurely. All of my
left (boosted) magneto spark plug leads go to the upper plugs in each
cylinder to ensure getting better odds of sparking than from a potentially
oil fouled lower plug.
nuckollsr(at)cox.net Guest
Posted: Wed Aug 30, 2006 5:53 pm Post subject: SlickSTART Bulletin SB1-06 |
At 06:21 PM 8/30/2006 -0400, you wrote:
8/30/2006
the associated wiring within 20 flight hours or at the next scheduled
the right one) P lead stud. During cranking this connection automatically
cause kickback.
ensure that the aircraft magneto / ignition switching system is such that
the non boosted magneto is grounded out during cranking by the switching
system.##
system".
Good data sir! Do you have a copy of the SB? Is it available on the
net? I'd like to have a copy for the archives.
< with experiment. >
< --Lawrence M. Krauss >
