chaztuna(at)adelphia.net Guest
Posted: Mon Sep 04, 2006 6:59 am Post subject: Alodine/Iridite accessories was Re: Iridite Wanted to Buy |
Chuck
That's a great tip, although keeping the solution warm is not a problem here in SE Florida. For the rest of the listers, I will suggest another item to buy while you are at the aquarium supply store. Buy an aquarium pump. This will aid in transferring the AlumiPrep and Alodine back to your storage buckets. I keep my chemicals in 5 gallon plastic buckets with sealing lids, like the ones that paint and dry wall spackle are sold in.
You can buy the buckets at Home Depot or Lowes. I get mine for free from a friend. He has a home remodeling business and is happy to give them to me. If you have a friend in the business, bum his excess buckets from him. You might also try looking in the dumpster behind your local house painter's shop.
Charlie Kuss
[quote]--> RV-List message posted by: "Chuck Jensen" <cjensen(at)dts9000.com>
Need to keep your alodine solution warm? Use an aquarium heater. All
the wetted component are plastic or glass. Buy a 1000w unit and it
should keep your solution warm and with no shock hazard.
Chuck Jensen
Vanremog(at)aol.com Guest
Posted: Mon Sep 04, 2006 11:08 am Post subject: Alodine/Iridite accessories was Re: Iridite Wanted to Buy |
In a message dated 9/4/2006 8:01:12 A.M. Pacific Daylight Time, chaztuna(at)adelphia.net writes:
| Quote: | That's a great tip, although keeping the solution warm is not a problem here in SE Florida. For the rest of the listers, I will suggest another item to buy while you are at the aquarium supply store. Buy an aquarium pump. This will aid in transferring the AlumiPrep and Alodine back to your storage buckets. I keep my chemicals in 5 gallon plastic buckets with sealing lids, like the ones that paint and dry wall spackle are sold in.
Another thing to get at the aquarium store is an aerating stone. The solution needs oxygen to maintain its properties for performing the conversion of the surface. This is the property that gets lost first (dissolved oxygen) or so I'm told.
GV (RV-6A N1GV O-360-A1A, C/S, Flying 807hrs, Silicon Valley, CA)
