		pwmac(at)sisna.com Guest
				 Posted: Mon Sep 04, 2006 3:00 pm    Post subject: 912UL Initial Engine Test  Run |
				Hugh,
 I have not followed closely. What steps did you
 take to bleed the air out of the coolant system?
 Its pretty common to have a big air pocket that
 is difficult to dislodge. If there is a pocket of
 air then overflow after shutdown would be
 expected as would excessive temps. I usually use
 a hand held vacuum pump for a bleed task.
 BTW, I would recommend spending the extra $$ and
 put in the  proper coolant. This will elevate the
 boiling point and the max allowable temp. The
 Rotax bulletin tells you which formulation to
 buy. A side benefit would be the low pressure in
 the system achieved with the new low pressure cap
 Rotax cap. This will allow longer life for the
 various coolant system seals. The only drawback is cost of coolant.
 Regards, Paul
 At 04:17 PM 9/4/2006, you wrote:
 McKay III" <hgmckay(at)bellsouth.net>
 Thom/Gilles:
 I have followed your dialogue with great interest, and it has helped me
 immensely. I have no experience with this engine, so I was alarmed when I
 saw the CHT continuing to rise. I was even more alarmed when I shut down,
 and heard the coolant boiling in the overflow bottle. I still don't know why
 this happened. There is no question that the engine was not being cooled
 properly, the question is why? It may have been a combination of existing
 circumstances (i.e. static engine run, no horizontal movement of plane,
 tarmac temp 88 degrees+, engine fully cowled with spinner, horizontal
 radiator, and length of operation). I do know that with the spinner on, the
 91/2 inch diameter spinner flange eats up most of the free area for air to
 enter the engine compartment. In fact there is only 18 square inches of free
 opening left for air to enter the engine compartment. This may be fine with
 the plane traveling at, say 90 mph, but maybe not with the plane sitting on
 the ground for 10 to 15 minutes in 88° F. I don't know, but certainly I
 would think the plane designers would design for this condition. What free
 opening does Rotax require on fully cowled engines?
 Since this was the initial engine start, I am going to call Lockwood Green
 tomorrow and explain every thing that happened to them and get their
 opinion. I'll keep both of you informed as to what they say. Again, thank
 you for your advice, counsel, experience, and knowledge.
 Hugh
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		hgmckay
				 Posted: Mon Sep 04, 2006 3:28 pm    Post subject: 912UL Initial Engine Test  Run |
				Paul:
 I did not bleed air out of the system. I did not know I had too! There is no
 information in the Rotax operators manual addressing cooling system "air
 pockets"! This is all news to me! Where is this "air pocket" supposed to
 form, and where and how do you remove it with a "hand held" vacuum pump?
 Hugh
		daveaustin2(at)can.rogers Guest
				 Posted: Mon Sep 04, 2006 4:03 pm    Post subject: 912UL Initial Engine Test  Run |
				Been watching this thread with interest as I had a boil during a flight back
 in the a/c early days.
 The key to the situation is that the coolant has boiled.  When it does, the
 vapour no longer carries the heat away and the local hotspot rapidly
 increases in temperature well beyond limits for the aluminium.  That causes
 distortion of the overheated area.
 I was using a 80% antifreeze mix at the time as instructed back then, and
 the heat transfer properties at that mixture is lower than at the usual 50%
 mix.  Changed to 50% and the boiling never occurred again.
 I'd do a careful compression test and coolant leak test at pressure.  Make
 sure coolant is not getting into the crankcase and into the oil.  If no
 problems,  run it again.  Make sure the cap is giving you the full pressure.
 Dave Austin  601HDS - 912, Spitfire Mk VIII
		bjohnson(at)satx.rr.com Guest
				 Posted: Mon Sep 04, 2006 8:35 pm    Post subject: 912UL Initial Engine Test  Run |
				Beware of using the evans coolant in a system (aircraft) not specifically
 designed for it.  I ended up in a baaaad situation with vapor lock (with
 100LL!!! And insulated fuel lines) after switching to evans.  Evans, while
 not boiling until well over 300F, also does not cool as well.  You WILL see
 at least 30F increase in normal operating temps with the evans coolant.
 -Bruce
 [quote] --
				 Posted: Tue Sep 05, 2006 6:02 am    Post subject: 912UL Initial Engine Test  Run |
				Normal procedure when a system has no high point
 bleed or when one suspects an air pocket, which
 is 100% of the time for me. Any mechanic would do
 this for brakes, power steering and coolant.
 Based on experience some engine coolant systems
 do not need it. In the case of the Rotax I would
 do it just to be sure. Any engine has air pockets
 after the first fill and some will self purge.
 Harbor Freight has a cheap hand operated vac
 pump. Get a rubber stopper from the hardware
 store drill a hole and put it in the filler and
 start sucking. Do this until the vacuum holds
 steady. You might have to get another pressure
 cap and drill a hole in it to get a proper seal.
 Study the coolant pipes to see what you have done
 that may have caused a place where the bubble
 could form. But, who cares just bleed it to be sure.
 Paul:
 Hugh
