dreel(at)cox.net Guest
Posted: Mon Sep 04, 2006 5:49 am Post subject: Forward Baggage Compartment Temperatures |
Yesterday I measured a 110 degree Fahrenheit temperature close to the
firewall in the forward baggage compartment of my RV8A. The method was to
tape the wire lead of the outdoor sensor of an indoor/outdoor digital
thermometer to the firewall so that the sensor was held close but not
actually in contact with the firewall. Upon return from a half hour flight,
I just opened the baggage compartment door and read the temperature about 5
minutes after landing. I also know that plastic bubble wrap which was in
contact with the firewall did not melt and that although you can touch the
firewall, it feels pretty hot. Outside air temp was 75 degrees F.
Does anyone else have any information on the temperatures likely to be
experienced by baggage stowed in this area?
Dave Reel - RV8A
martin(at)gbonline.com Guest
Posted: Tue Sep 05, 2006 5:29 pm Post subject: Forward Baggage Compartment Temperatures |
Dave,
Suggest you consider insulating the firewall with 3M Vibration Dampinng Tape
or equivalent. This will provide a fire barrier and also reduce temps to
normal cabin temps. This is a standard insulation for aircraft and is
readily available.
Dick Martin
RV8 N233M
the fast one
