_lr_(at)yahoo.com Guest
Posted: Wed Aug 23, 2006 5:14 am Post subject: Build times - time to get restarted? |
I was one of the first to buy a tail kit (#22), but life intruded and
after some initial progress the kid has been untouched for the last 2
years. I'm now getting the itch to get hack into the project, but I'm
wonder if I've bit off more than I can chew.
I'd be interested in hearing from anyone who has completed, or nearly
completed a Quick-Build RV-10, regard times to completion for each of
the sub-kits (empecone, wings, etc). Did you try to optimize for lowest
cost of fastest build time? What major obstacles did you hit? What
words of advice/encouragement would you offer?
Its getting depressing to see the tail parts hanging there every time I
pull into the garage. Its time for me to either get my you-know-what in
gear or admit to myself that this isn't going to happen and sell the
tail kit.
Replies directly to this email _lr_(at)yahoo.com are welcome.
Thanks in advance,
Larry Rachman
ISP
john.erickson(at)cox.net Guest
Posted: Wed Aug 23, 2006 6:30 am Post subject: Build times - time to get restarted? |
Larry,
I've got kit #40208 and have also been getting discouraged now and then as I
see guys with slowbuild numbers well after mine flying already. I'm
military, have a couple kids, and while my building hasn't stopped (other
than during a couple deployments), let's just say the wing flaps have taken
me over 9 months so far, and not because the flaps are difficult.
That being said, when I first started building a couple years ago, I set a
goal of flying in 2 - 3 years. Obviously not going to happen. I changed my
goal a year or so ago. I enjoy building. A lot. However, when I try to put
a deadline on the project, it seems to turn from a fun project to a job.
I've decided I'm going to work on it at whatever pace is enjoyable, and it
will fly when it flies. (or as someone on the list said, I'll fly it when I
run out of parts.)
My recommendation. Get the tools out and get your shop set back up. Don't
try to power through building your plane (besides, we're not building
airplanes, we're building hundreds of small projects that end up flying in
close formation). Spend 5 minutes out in the garage doing a little bit.
Spend 4 hours if it feels good (and the family lets you). Just go out there
a couple times a week and say hi to the project. Eventually it will be
done. Don't worry about times for subcomponents or total build because then
you WILL get depressed when, like me, you find it takes longer to build part
X than Joe Bagodonuts took to do the same thing.
Just my $0.02 worth...
#40208 Wings (still)
mritter509(at)msn.com Guest
Posted: Wed Aug 23, 2006 6:51 am Post subject: Build times - time to get restarted? |
Larry,
I purchased tail kit #43 November 1, 2003 (QB Fuse and wings). The plane
was inspected on July 21 and I flew it on July 22, 2006. I worked on the
project two or three days most weeks and didn't let it consume all my free
time. Saving time for the grandchildren, fishing and a little time at the
office around pay day was just as important as finishing the plane. I
wanted to keep the project "fun". Some days you just have to say the hell
with it and go do something else.
Early on I decided not to keep track of my time or cost. It was going to
take what it took and I sure didn't want to set any deadlines. I get enough
of that stuff at my CPA office.
In my case it seemed to be more fun when I could enlist the help of friends
and enjoy a cold one at the end of a day bucking rivets. Most of my
friends will work for beer.
The plane is great and performs as advertised but I really enjoyed the
building. Learning new skills and the sense of accomplishment is what it
was all about for me.
Mark
| Quote: | From: Larry R <_lr_(at)yahoo.com>
Subject: Build times - time to get restarted?
Date: Wed, 23 Aug 2006 06:13:28 -0700 (PDT)
tail kit.
Thanks in advance,
Larry Rachman
ISP
Rick S.
Posted: Wed Aug 23, 2006 8:59 am Post subject: Build times - time to get restarted? |
What John fails to mention is he has a flying RV-8 that consumes some of his time as well
I have reached some sort of burnout several times. Deems and I share the same dislike for the summer heat, which will set you back becasue it robs your attention to detail. Work, family demands, busted fingers all play a part. John is 100% right when he say if it starts to feel like a job, take a break. I'm in no hurry, I'm 40185 slow build. I'm doing a bunch of wiring which I totally enjoy but sitting in the background is that darn glass top, which until I stop swaeting out a gallon of water a day it will sit there waiting for nice cool fall temps. I have always held to the do SOMETHING each day theory, be it cleaning up, reading plans, deburring parts from way ahead in the build, (which is really nice when you come to that part and find it ready to drill, dimple and install) The other RV forums have all addressed this issue so you far from being alone. To a point I think we all have flet this was too much to take on at some point then you work past it. I've been at it since Feb 2004 and won't even speculate as to my completion date. Sam Buchannon said at some point your going to run outta parts, then it's time to fly.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
Jim & Julie Wade
Posted: Wed Aug 23, 2006 9:28 am Post subject: Re: Build times - time to get restarted? |
I work heat better that cold!!!! Big hanger can't heat well. I have a big water fan!!!! You know with the water trickling down the back grates. Drops the temp 15 degrees up to 30 feet in front of it. I have worked all summer in 100+ temps with no problem!!!!
Back to the kit!! How do you eat an elephant?????
One bite at a time!!!!!!!!!!!!!!!
I to went through depressed times. Everyone will!!!!!
Jim
383
bcondrey
Posted: Wed Aug 23, 2006 9:46 am Post subject: Build times - time to get restarted? |
I have had numerous interruptions of weeks at a time due to work related
travel. Frequently it's hard to get restarted but picking a specific
task to work makes getting your arms around it a lot easier. I have
done my plane using slow build versions of the kits. I was too
optimistic for timing on both the wing and fuselage kits - they sat
around for weeks/months before I completed the preceding kit and was
ready to move on.
One thing that is HUGE motivation is a ride in a friends' RV - check out
your local EAA chapter and I'm sure you'll find somebody willing to take
you up.
Bob #40105
Back to engine baffling after a few week break for OSH and work
travel...
wayne.e(at)grandecom.net Guest
Posted: Thu Aug 24, 2006 3:25 am Post subject: Build times - time to get restarted? |
I'm obviously not understanding something. A person will make a posting and at the bottom of the posting it will say
http://forums.matronics.com/viewtopic.php?p=56714#56714
which will be the same thing that I just read but in a little different format. What is the purpose of this, to post to two different sites?
Wayne Edgerton # 40336
Tim(at)MyRV10.com Guest
Posted: Thu Aug 24, 2006 7:27 am Post subject: Build times - time to get restarted? |
It's because Matronics can be read by email or from a web
forum, either way. This is just a link into the
web forum.
Wayne Edgerton wrote:
| Quote: | I'm obviously not understanding something. A person will make a posting
jjessen
Posted: Wed Sep 06, 2006 2:32 pm Post subject: Build times - time to get restarted? |
Larry:
Others have given replies to this that are on target, but I want to share a
thought or two since I have come very close to selling my project a couple
of times and found I could not let it go. I almost didn't bite on this
topic because of the personal nature that encompasses why each of us builds.
We all love flying and to a degree building, but beyond that I'm sure we
each have our reasons to take on such large a project, and thus wasn't sure
if my two cents meant much beyond me.
I have often said to my friends and fellow builders that if I can't get this
plane in the air in two or three years then why bother. I'm getting older
and the reason to build is to fly a plane that is way more than I could have
afforded otherwise, one that is fast, great to fly, holds a bunch,
comfortable, and so on. I've also said to friends and fellow builders that
I don't keep track of my build time (or at least very accurately) because I
love to build and this thing will get done when it gets done. I've looked
at my wallet a few times and have heard the echoes of emptiness that reminds
one of a vast cave, a deep cavern with no chance of filling up while this
project continues. I've read Tim's thoughts, as well as others, that we
best be enjoying flying now, for we may not be able to for long, given this
and that cost or this or that regulation, and I've practically gone into a
psychological tail spin thinking of all the problems and consequences.
But.......
I cannot wait to get out to the hanger and back at it after this latest
round of a month hiatus due to travel. I may never finish in the timeframe
that I'd like, but I love the building and the camaraderie so much, and it
has become such a part of my thinking, my daily mental routine, that I doubt
I'd be happy without it. I've fallen behind my goals, and my building
neighbors, but I've learned so much about so many things that would have
passed me by. More importantly, I've learned more about myself, my ability
to learn new skills, to improvise, to seek out answers based in fact, to
enjoy the time spent at a project that will become a legacy to those who
know me and my love of flying. Even if I only get to fly it for a few
years, my son will love it, and what a gift to give to another who loves
flying so much. This will be as much of a legacy gift as any of the other
things I've built, and in the meantime I'll have had a wealth of good
feeling making all those parts fly in close formation and meeting all the
folks along the way.
Anyway, I guess my point is that, if you can find the time, and if you can
find the resources over that time, I wouldn't get depressed at the progress.
Decide what it means to you to build, not what it means to you to hurry up
and fly. If you love the building, then let it be the most compelling and
amazingly broad hobby a person can have. It'll take a few more years then
you'd planned, but what good project doesn't demand more of us? If you
really want it done faster, then plan on at least one night a week, maybe
two, that you set aside for building, plus one full weekend day. Negotiate
that with your family and then stick to it, except for family time. You do
not have to build this magnificent flying machine, but you certainly can and
will if you want to! Plus, you'll have the support of all us other
builders, cheering each of us on.
John Jessen
Tailcone 40328
dav1111(at)cox.net Guest
Posted: Thu Sep 07, 2006 2:02 am Post subject: Build times - time to get restarted? |
Larry:
First let me give you my background so you have some perspective to work
from. I am a 60 year old first time builder with 1500+ hours flying time,
an instrument ticket, and a full time law practice. My first five airplanes
were three C182's, a C-177, and a Bellance Super Viking.
My sixth airplane was an RV-6A which I purchased. I loved it so much that
when the RV-10 came out I decided I had to build it in order to have both an
RV and a four place airplane. From October of 2003 until about July of 2004
I worked on the Emp/Tailcone kit getting it mostly built. I had an A&P
friend who taught me the basic building skills and gave me a hand at times
when it really helps to have a second pair of hands (there are a lot of
those times). When the QB wings arrived I did a little work on them while
finishing up on the Emp/Tailcone but the wings I basically set aside after
receiving the QB fuselage and worked on it until about March of 2005 when
one of my best friends (and RV-10 builder) passed away. I spent most of my
spare time over the next three months helping his widow get his RV-10,
engine, and prop sold. I then had three major surgeries during the period
of May-August of 2005. When I recovered and got back to building in
November of 2005 I pushed ahead with every free waking hour (average 6 hours
sleep a night) until I finished my RV-10 and flew it on 7/28/06.
Thirty three months from start to finish including the over 8 months of down
time, and keeping my solo law office afloat.
Would I do it again? In a heart beat!! I have enjoyed the building process
even though the last three months were hell on wheels because of the
deadline I set for myself of flying to OSH2006. I flew the week of OSH2006
just not to OSH2006. So close yet so far away.
My -10 is in the paint shop at GLO Custom Paint and I am due to get it back
next week. I can hardly wait.
Had I not sold my RV-6A early during the building process I would not have
pushed myself so hard to get the RV-10 built by OSH2006, but on the other
hand I am really glad I sold when I did as I obtained a really good price
and it helped pay for the RV-10 build.
If you are not going to make a commitment to build, now is the time to sell
your Emp/Tail kit. Building an RV-10 takes both a commitment of time as
well as money. From a time standpoint you will be better off committing a
regular consistent amount of time, whether that is 10 hours a week or closer
to 20 hours a week for part time building. The long layoff's and stop/start
of the building process is not helpful and will cause you to have to spend a
lot of extra time just getting back up to speed in the building process.
| Quote: | From a money standpoint, I did not build cheap, however I probably have
about $150,000.00 in my RV-10, but I didn't go as expensive as some who I am
sure will have $200,000 or more in their RV-10. I doubt you can do a decent
job of building a quality RV-10 for less than about $125,000.00.
I hope this helps you make a decision. One thing I assure you of, if you
decide to the building commitment there are a lot of really great guys out
there who can help you with advise, pictures, and encouragement. The RV
community is one of the best groups of guys and girls you will ever come
across. If you are not active in a local EAA chapter I would also encourage
you to get active as the EAA group is great as well.
Russ Daves
N710RV flying
[quote] --
bldgrv10450(at)comcast.ne Guest
Posted: Thu Sep 07, 2006 9:18 am Post subject: Build times - time to get restarted? |
Larry
I enjoyed the history and detail of your build process. I am having a great
time work on kit 450 fuselage now. It's fun to look at all the beautiful
RV10's completed but, some how it seems more achievable when you read the
history of your completion. When your in the process concentrating on each
little detail the overall task seems daunting, but bit by bit you look at
what you have completed and the building of an RV10 is a truly rewarding
undertaking.
Paul Grimstad
RV10 #40450 fuselage
Portland, OR
