iworonko(at)cox.net Guest
Posted: Thu Sep 07, 2006 3:01 pm Post subject: master cylinder |
Hi folks,
I have just installed the main gear and hooked up bled the brakes. Piston in the left master cylinder has about 1/2" of free travel before brake pressure is applied. Right side is very tight, it has less then 1/8" free travel before pressure is applied. Because there is virtually no free travel I cant push the rudder pedal all the way forward before the brake applies and the pressurized cylinder stops forward travel of the pedal. It is not rod adjustment . I disconnected the cylinder from the pedal and it is still tight. Also, disassembled the master cylinder-looks ok inside.
Any ideas?
Eric
henrysfork1(at)msn.com Guest
Posted: Thu Sep 07, 2006 5:06 pm Post subject: master cylinder |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Eric, I had to tape the adjustment rod down lower.
Dee
jose_m_toro(at)yahoo.com Guest
Posted: Thu Sep 07, 2006 5:44 pm Post subject: master cylinder |
Eric:
If the symmetry between the pedal and the master
cylinder is correct, you will be able to apply full
rudder either direction without automatically applying
pressure to the cylinder. This also imples that, even
if a master cylinder piston is stucked, you should
still be able to have full travel with both pedals.
Seems to me like there is something wrong with the
installation of both master cylinders. You will need
to change the position where the master cylinder
pivots in the pedals assembly attachment brackets.
You may need to redo those brackets.
If you check site www.matcomfg.com, there is a drawing
showing the right symmetry between the pedal and the
master cylinder.
Jose
--- Eric <iworonko(at)cox.net> wrote:
| Quote: | Hi folks,
Any ideas?
Eric
smokey_bear_40220(at)yaho Guest
Posted: Thu Sep 07, 2006 7:06 pm Post subject: master cylinder |
Check your right brake, or swap master cylinders and
replenish the fluid. See if it is the master or slave
cylinder.
To me, it sounds like the master. See if it actually
locks the right brake with such little travel, or is
it self limiting?
I agree with what you already heard. The cylinder
shouldn't limit the pedal travel in any case.
Kurt S.
| Quote: | Hi folks,
Any ideas?
Eric
ddsyverson(at)comcast.net Guest
Posted: Sat Sep 09, 2006 6:13 pm Post subject: master cylinder |
Eric,
Just an idea, and I don't know it it is applicable to your situation or not.
Here is what I ran into on the master cylinders. I purchased a dual brake
system from Sky&#$^. After Sky&#$^ dissappeared, I found that I had two
different cylinder models; two Matco MC-4A cylinders, which were the correct
length, and two Matco MC-4 master cylinders which were too long for the
application. The bodys of both the MC-4A and MC-4 were identical, the
difference was in the lenght of the piston rod and some internal parts. The
MC-4 piston rods were about 1/2" longer and resulted in exactly the same
geometry problem with the rudder pedals which you described.
I realize that you said the cylinder length was not a problem, but there is
some adjustment on the screw end of the piston rod which might make it
possible to get the adjustment (eye to eye) close for the two models of
cylinders yet still cause problems with the geometry.
I can't say you have the same problem, but you might want to check to be sure
both sets of cylinders are the correct model number for the kit.
At any rate, Matco helped me out by exchanging the cylinders for a very
reasonable rate and providing the tech data to figure the problem out. The
individual I dealt with was:
George R. Happ
MATCO mfg
801-486-7574 801-486-7581 (F)
www.matcomfg.com
If the installation is still a problem, I would sincerely suggest contacting
George. They know their products and also know how to treat people right.
(No-they did not pay me to say that-its experience with them speaking) If you
are stuck - I believe that MATCO will be able to help you figure the problem
out.
Sincerely,
Dave S
St Paul, MN
Kitfox 7(training wheel on the front)
On Thursday 07 September 2006 6:00 pm, Eric wrote:
| Quote: | Hi folks,
is still tight. Also, disassembled the master cylinder-looks ok inside. Any
ideas?
Eric
