cjhukill(at)cox.net Guest
Posted: Sat Sep 09, 2006 6:42 am Post subject: Heat selector valve |
I concur completely that Don at Aviacomp is the man to see about anything for your heating system. At my request, he redesigned the T that goes in the forward tunnel to direct the heat to the forward footwell areas, to include a selector valve. It is a drop in replacement for the original, and with the use of a cable, I can now mix the forward heat to either side, a must have requirement for my cold blooded other half, flying partner. It was a true pleasure working with Don on this very simple, yet useful mod, that Vans should offer in their accessory catalog. If you need to see a picture, email me cjhukill(at)cox.net (cjhukill(at)cox.net)
Chris Hukill
fitting the plastic wheelpants, really out of sequence
(cannot believe people actually build whole airplanes out of that stuff!)
