flaps and flexibility
akucheck(at)gmail.com
PostPosted: Sun Jan 22, 2006 10:58 am    Post subject: flaps and flexibility Reply with quote
So do answers given to this point change significantly when there is a
strong crosswind?
Last week a very unusual circumstance occurred at SNA: I took off on a
short flight to check out a couple of maintenance items. The ATIS was
calling the wind 200/7 and runways 19 were in use. The windsock confirmed;
perfectly normal day down here. I did a short flight and returned for a
practice ILS approach to 19R. Weather was CAVU and the air was relatively
smooth. As I got lined up on the approach I got my first indication that
things had changed: I had not been airborne for more than 20 minutes, yet
now on approach I had a WCA of at about 25 degrees to the right to remain on
the ILS. I was really surprised - what is going on here?. "John Wayne
tower, windcheck, please." "Winds 250 at 18 gusting 25". Interesting...
So I had the opportunity to land back at SNA [nice wide runway] with a
crosswind component of about 15Kts and gusting higher. This is an area where
I have precious little experience in my bird. As it turned out, this was
one of my better landings ["nothing focuses the mind so much as an imminent
hanging"], but I'm frankly unsure of any Commander-specific recommendations
for this kind of situation. On this day I used half flaps while carrying a
little extra airspeed for the gusts, and consumed significantly more runway
than I usually do.
What is the consensus on flaps and crosswinds? I have been taught [not
Commander-specific] that strong crosswinds should be met with minimal to
partial flaps. Agree/disagree for Commanders?
Separately, is there a maximum demonstrated crosswind component for Aero
Commanders?
Alan
john(at)vormbaum.com
PostPosted: Sun Jan 22, 2006 2:34 pm    Post subject: flaps and flexibility Reply with quote
Hi Alan,
Here at PAO we have frequent 90-degree crosswinds. At DVO, where I fly to
see my in-laws, the predominant winds are directly across the runway. I've
never modified my flap usage in those circumstances, and I can easily slip
the airplane down, landing upwind wheel first, and using no more runway than
usual.
I seem to recall that twins aren't required to demonstrate a maximum
crosswind component, and have never seen any for a Commander. I can say that
I've landed mine in a 30-kt. crosswind (yes...THIRTY!) without any hint of
loss of directional control. I also seem to recall that the max demonstrated
crosswind component for most singles is often the highest crosswind
experienced by the test pilots during certification....
If you want good crosswind practice, I suggest going to DVO (north of SF)
the next time you're up here!
/J
PostPosted: Sun Jan 22, 2006 2:47 pm    Post subject: flaps and flexibility Reply with quote
John:
Thanks for the feedback on x-winds.
..interesting that you mention DVO. There is a good likelihood that I will
do a fair number of SNA-DVO trips this year. Looking at AirNav, I don't see
any fuel or car rental available. Any experience with either there?
Alan
nico(at)cybersuperstore.c
PostPosted: Sun Jan 22, 2006 5:43 pm    Post subject: flaps and flexibility Reply with quote
I am no airline jock or someone with the privileges that military training
offer. What I had I had to pay for at the local flying school back in the
60's. That was supplemented by many 'Oh sh.t, better not attempt that again'
over the years doing a lot of bush flying. After that disclaimer, back to
the topic.
On cross-winds I key in a slightly higher speed (for gusts as Alan said) and
full flaps. Even Cessna 150's will have all the flaps hanging out upon
landing. In rough air, as soon as I have firm contact with the runway, I
will raise all the flaps. In smooth air, I use the drag to reduce brake use.
Now, I know, many of you will say, one day you're gonna pull the wheels up
and have a very short step down to the runway, but I do a very short-final
check on wheels-down by actually touching (fondling?) the gear handle down
and locked (the Commander's unique lock) and so mentally confirming that the
other handle is the flaps. Raising the flaps drops all tendency to keep on
flying (in case of a gust) and rapidly gives me firm automobile qualities.
There is an exception, however, and that is when wind gusts rock the
airspeed indicator more than 10 knots. For fear of exceeding the flap
extension speed and reducing bending moment on the wing, I will decrease
flaps. Every situation requires its own judgment.
Now I am open to criticism. I can take it.
Nico
with more formal training
PostPosted: Sun Jan 22, 2006 7:43 pm    Post subject: flaps and flexibility Reply with quote
Alan,
There's an Enterprise about 15 min. away from DVO, and they will deliver a
car to you there. I recommend calling well in advance and being very
optimistic on your arrival time as it has taken them up to an hour past when
they say it'll be there for them to actually show up with the car. Their
contact info is:
ENTERPRISE
7401 REDWOOD BLVD
NOVATO, CA 94945-2423
Tel.: (415) 898-3500
There's Also Novato Cab at 415-485-1234. On weekends there are only 2 cabs
on duty and it can take them ~45 minutes to get to you.
There is Chevron Fuel on the field and they have a truck....I don't have the
phone number and can't remember the unicom freq. for them but it's posted at
the terminal and they've proven very accessible even at odd times.
Incidentally I twice did the same test that you did, only with one key
difference: they weren't voluntary...I actually had 2 complete hydraulic
failures, one in my airplane and one in someone else's semi-restored 500B.
The runway available in each instance was 7,000 ft and 5,000 ft
respectively. Both times I held the nose off and used aerodynamic drag to
slow the airplane down (and avoid nosegear collapse; both times I had no
green light for the nosegear). Both times I had to add power to keep the
nose off and make it to the end of the runway. The incident in my airplane
resulted in a very gentle nosegear collapse on the taxiway at about 5 kts.
(user error....I tried to get too clever while airborne after recognizing
the failure), and in the borrowed airplane it was a non-event. I never
thought about distances, but on hindsight I think both airplanes would have
stopped shy of 3,000 feet. I attribute this to holding the nose off to avoid
the nosegear collapse; it REALLY slows the airplane down on the ground and I
think it would be a viable tactic should you have the same problem.
The only good news coming from this experience is the recognition that there
are very few conventional failures that could be considered emergencies in
Commanders, and the fact that my nosegear collapse cost me only a bellcrank
and one gear door...whew!
Also, I discovered that while rolling out on the mains, with a little power
added, you can maintain elevator authority at very slow speed (~25kts?); I
kicked in some rudder, and turned 90 degrees onto the taxiway quite easily
with the nose pretty high in the air. I probably could have taxied under
power all the way to Morris' hangar before letting the nosegear collapse,
but that would have just made it easier for Morris to slap me for making
such a rookie mistake Wink. You know, the airborne one where I touched the
gear lever one too many times after the loss of hyd. pressure.
BillLeff1(at)aol.com
PostPosted: Tue Jan 24, 2006 7:15 pm    Post subject: flaps and flexibility Reply with quote
I recommend full flaps on all landings except maybe very icy runways. Use
differential power when exceeding more than 1/2 rudder travel. When on the
ground the aircraft has a negative angle of attack and sticks quite well.
Raising the flaps after touchdown helps some but they retract so slow you will be
stopped before they are completely up.
Bill Leff
cloudcraft(at)aol.com
PostPosted: Wed Jan 25, 2006 6:39 am    Post subject: flaps and flexibility Reply with quote
Outstanding advice from Bill Leff.
Since Mr. Leff brought up the icy runway idea ... the ONLY time I'd
use less than full flaps when landing a Twin Commander was if I was
carrying airframe ice on the approach. Full flaps could aggravate a
tail plane stall.
I wonder if anyone else caught the very sublte but very important
hint: Bill Leff is offering Commander Training. If I was looking for
Commander training, I'd go to him (and I used to make my living doing
Commander training!).
I've landed in snarling, ripping, Santa Anas tumbleweed blowing,
sand-blasting, 90 degree cross winds in a Commander. Full flaps.
Differential power does the trick, coupled with that nice high wing
that allows all the side slip bank angle you could ever want.
Wing Commander Gordon
Imperial Meat Pie? Bill Hamilton, I may print and frame your Oz
Aviation History post!
n395v
PostPosted: Wed Jan 25, 2006 6:50 am    Post subject: Re: flaps and flexibility Reply with quote
There is nothing safer than intimate knowledge of your plane from an operational and design standpoint. It was Keiths intimate knowledge of the 685 that enabled me to finally become a competent pilot and a complement from Keith is indeed high praise.
Milt
bob.steele(at)kzf.com
PostPosted: Wed Jan 25, 2006 11:43 am    Post subject: flaps and flexibility Reply with quote
I will second WCG's suggestion on Bill. And I speak from experience.
I bought my Commander without having my ME rating. Dick Wartinger did the
pre-buy for me and then hooked me up with Bill. At the time Bill was an
MD-80 instructor at TWA (now American). Due to insurance requirements I had
to spend 25 hours with him and I can tell you he did everything in the world
to me - including pulling engines on take off roll - before and just after
take off (and on hot days). Bill is definitely old school as well as new
school. I think I was his first piston student in 20 years - so he insisted
on the best of the good-old-days as well as the new stuff of today.
One of the best things he had me do was may make an actual single engine
landing - not simulated - but feathered left engine out - and because of his
training it was a snap - and it was as if he had ESP. To make a long story
short - on my ME check ride (with a for-real FAA employee as the examiner) I
actually had to make a single engine landing. It was a very hot summer day
in August and we were 10 miles from the airport with the right engine out
(long story there). Due to Bill's training I was not a bit nervous and the
landing at Lunken was a breeze - even taxied all the way back to the FBO and
parked her in an out of the way spot! (I got a discontinuance because the
FAA man wanted two to see two more take offs and landings - which he got out
of me two weeks later.)
Thanks to Dick Wartinger I now a have a great instructor and a friend.
Bob Steele
Prestigious Holder of the 2005 Golden Rudder Award
Can't wait to give it to someone else in Dayton this summer
PostPosted: Wed Jan 25, 2006 1:26 pm    Post subject: flaps and flexibility Reply with quote
Great history, Bob.
What's the golden rudder award, Bob?
Pardon my ignorance.
wjrhamilton(at)optusnet.c
PostPosted: Fri Jan 27, 2006 6:09 am    Post subject: flaps and flexibility Reply with quote
Folks,
Please feel free to reprint any of my ramblings.
Bill Hamilton
PostPosted: Tue Feb 07, 2006 12:07 pm    Post subject: flaps and flexibility Reply with quote
Nico,
I just saw this e-mail, sorry for the slow response.
At the annual Fly-Ins the guys/gals who get there early - mainly Captain Jim
Bob and basically everyone else who is there before you arrive - judge your
taxing. Whoever does the ugliest job of it, which apparently I did in 2005
at Marina, CA, wins the dang thing.
From what I can tell - it's all political, there is nepotism involved,
price-fixing, bribery, and all other kinds of orneriness. The only good
thing for 2006 - my hanger is next to Commander-Aero and the only way I can
win it back to back is if they include "planes being parked by a tug!"
Just to be safe, I think I'll just have it parked outside Commaner Aeros's
hanger the day before JB gets there.
Bob Steele
