Alternator longevity?
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List
MPPalmer(at)aol.com
PostPosted: Fri Sep 08, 2006 11:08 pm    Post subject: Alternator longevity? Reply with quote
We have the Motorola 60A alternator S/H offered as an option 20 years ago. Comes with larger pulley to reduce rotational speed. Still, I have to overhaul it every 400 to 500 hours.
Have had to replace one case half (fretting), always bearings (upgraded to HD bearings, but not much improvement), sometimes diodes, and this last time, the stator failed from vibration. Just about every part has failed at 2600 hrs except the rotor. Have a blast tube blowing on the alternator for some cooling.
Am wondering what kind of time between overhaul you all are seeing on alternators? What lasts the longest? I'd switch to the Nippon everyone seems to use, but we have an old narrow deck engine, and I have a funky, custom bracket that I'd rather not re-engineer.
Mike Palmer <><
www.members.cox.net/mppalmer/
FT gear bracket crack [quote][b]
- The Matronics Glasair-List Email Forum -
http://www.matronics.com/Navigator?Glasair-List
jdhcv(at)yahoo.com
PostPosted: Sat Sep 09, 2006 7:13 am    Post subject: Alternator longevity? Reply with quote
Hi Mike, you probably aren't going to have much luck
with your question. Very few people on this list have
enough hours on their aircrft to wear one out. ;<)
all are seeing on
Mike Palmer <><
Craymondw(at)aol.com
PostPosted: Mon Sep 11, 2006 7:01 pm    Post subject: Alternator longevity? Reply with quote
I bought a used low time alternator from Wentworth that came off a Bonanza and have 1,000 hours on it. Glasair2S FT 200 HP Lycoming [quote][b]
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List All times are GMT - 8 Hours
