djones(at)northboone.net Guest
Posted: Wed Sep 13, 2006 5:11 pm Post subject: Transponders |
In a transponder what is considered suppression out and remote ground when used in the wire harness.
Dennis
wgill10(at)comcast.net Guest
Posted: Wed Sep 13, 2006 6:20 pm Post subject: Transponders |
Hello Dennis,
What brand of transponder are you dealing with?
Posted: Wed Sep 13, 2006 6:44 pm Post subject: Transponders |
Terra TRT 250D
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of William Gill
Sent: Wednesday, September 13, 2006 9:20 PM
Subject: RE: AeroElectric-List: Transponders
Hello Dennis,
brian-av(at)lloyd.com Guest
Posted: Thu Sep 14, 2006 5:09 am Post subject: Transponders |
On Sep 13, 2006, at 6:03 PM, Dennis Jones wrote:
Quote: | In a transponder what is considered suppression out and remote
The suppression pin there there to effectively mute the reply from
your transponder when the signal comes from your DME.
The DME is at a frequency very near to that of the transponder. When
the DME transmitter sends out a couple hundred watt pulse the
transponder's receiver is overloaded. It may generate a reply. To get
around this problem the DME puts a pulse on the suppression line when
it is getting ready to transmit. This inhibits the transponder from
responding and sending out a bogus reply.
If you have a DME you should connect its suppression output to the
suppression input of the transponder. No DME? No worry.
Brian Lloyd 361 Catterline Way
brian HYPHEN av AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
Bill Denton
Joined: 10 Jan 2006 Posts: 97 Location: Chicago, IL USA
Posted: Thu Sep 14, 2006 5:52 am Post subject: Transponders |
It's also used in instances where you have two (or more!) transponders in an
aircraft...
fvalarm(at)rapidnet.net Guest
Posted: Thu Sep 14, 2006 8:29 am Post subject: Transponders |
Yes,
Why would you want two (or more) transponders in an your aircraft?
Bevan
RV7A Finishing kit
oldbob(at)BeechOwners.com Guest
Posted: Thu Sep 14, 2006 8:42 am Post subject: Transponders |
Good Morning Bevan,
For the same reason many aircraft have two VORs or two
GPSs.
Redundancy.
Most air carrier, and many corporate aircraft, have
dual transponders.
If I were based in an area such as the SFO bay area, I
would also consider having two installed. Without a
transponder in such an area, even VFR flight is
difficult.
Happy Skies,
Old Bob
--- B Tomm <fvalarm(at)rapidnet.net> wrote:
Yes,
your aircraft?
Bevan
RV7A Finishing kit
frank.hinde(at)hp.com Guest
Bill Denton
Posted: Thu Sep 14, 2006 10:47 am Post subject: Transponders |
Dunno, but Piper offers them in their "big" aircraft, and I think they may
be used in the turboprop world...
Kellym
Posted: Thu Sep 14, 2006 11:03 am Post subject: Transponders |
So that when you are in the middle of the DC ADIZ and one quits
squawking you don't get interecpted by F-16s.
Quote: |
Yes,
Bevan
RV7A Finishing kit
KCHD |
Posted: Thu Sep 14, 2006 11:42 am Post subject: Transponders |
I guess it depends on where you fly. Where I fly, transponders are
mandatory but quite often ATC tells us they can't "see" it. We tell them
it's still turned on and they clear us to where we want to go anyway. It
makes me think its mandatory to have but intermittent operation is OK.
Incidentally the transponders check out fine in the shop. The general
consensus is that Act's system is unreliable due to various factors.
Bevan
Posted: Thu Sep 14, 2006 12:58 pm Post subject: Transponders |
Thank you Brian
What is the remote ground used for?
Quoting Brian Lloyd <brian-av(at)lloyd.com>:
when it is getting ready to transmit. This inhibits the transponder
from responding and sending out a bogus reply.
