klehman(at)albedo.net Guest
Posted: Sat Sep 09, 2006 12:31 pm Post subject: John Deere PM alternator regulator |
I can now say for certain that the AM101406 regulator will not come to
life with a totally dead battery. Since I was at homebase, without
power for a charger, and like to experiment, I attempted to charge the
dead battery by closing the Z-14 cross feed contactor and charging the
dead battery with the good alternator for a few minutes until the PM
alternator came to life. I wouldn't recommend that and in this case it
seems to have caused the regulator to fail full on. I don't really know
why it failed as the rpm was modest (well below the max output
capability of the 20 amp PM alternator) and it is not particularly
uncommon to have dead batteries on the small tractors that these are
original equipment on. Further the regulator is on the cool side of the
firewall.
My best theory is that the totally dead small AGM battery allowed the
output to overvoltage some component in the regulator. I do not have a
battery contactor so I felt that there was no need for a large
electrolytic capacitor on the output since the battery would never be
disconnected. The oem application doesn't have a capacitor. AFAIK
totally dead batteries can be reluctant to take a charge at first so
maybe it wasn't absorbing enough current initially to dampen the output
pulses?? Again I wouldn't have expected that to fail a regulator
designed to work with up to 200vac open circuit voltage from the alternator.
The OVM worked perfectly. It is wired to interupt the line from the
alternator to the regulator. In further experimenting, the little 40 amp
relay does not seem to have suffered noticeably from a few 20 amp
disconnects. I also learned that a single 9ah battery will start the
subaru rather nicely so all in all I have obtained some value for the
cost of my experimentation I guess I also obtained some value from
the OVM modules
As a shot in the dark I am thinking of putting a capacitor on the output
of the regulator. That would leave the capacitor permanently wired
across the battery through the b-lead circuit breaker. I don't think
transorbs there would help. Any other suggestions? The obvious one is to
charge the battery first but that is not always convenient as sooner or
later I will likely run a battery dead again in some out of the way place.
I do not have a charging indicator lamp wired to the regulator but I am
assuming that is irrelevant.
Ken
dcarter11(at)sbcglobal.ne Guest
Posted: Sat Sep 09, 2006 8:37 pm Post subject: John Deere PM alternator regulator |
Ken,
For my info what is your last name? I thought at first you would be Ken
Powell who I have shared info with about Deere PM alternators, but the
e-mail address is different.
In any case, could you will in some of the "scenario":
1. The battery was dead, and you charged the battery from a non-PM
alternator after starting the engine.
. . . So, you have two batteries, 1 was dead, 1 was OK enough to start
engine.
. . . You have two alternators (a PM and a "standard" - not a bad idea when
building experience with an unproven application like a Deere on an
airplane)
. . . . . and used the non-PM to attempt to charge the dead battery.
2. Was the PM alternator isolated from the good battery so it or its Deere
voltage regulator lacked some needed "excitation"?
Looks like we need a "functional test" (experiment) to determine
characteristics of a Deere PM alternator and VR to see how it performs in
our application: We should find out "on a bench" that the Deere system
won't work with a dead battery.
Actually, there are two dead battery cases that come to mind:
1. Before flight, battery is dead. Don't fly with dead battery - so this
is a ground maintenance scenario.
2. During flight, battery dies and I want to continue flight with my PM
alternator to some suitable landing spot, either "soon" or "procede to final
destination" (whatever my risk analysis and good judgement and experience
and prior planning for this scenario may indicate is "safe enough")
. . . I plan to have two batteries, so 2. would have to include loss of BOTH
batteries or some portion of the electrical circuit.
Does you experience in this case you are reporting indicate that the PM
alternator system might stop putting out voltage and current if battery
power is lost?
David Carter
Posted: Sun Sep 10, 2006 4:38 am Post subject: John Deere PM alternator regulator |
David Carter wrote:
Quote: |
<dcarter11(at)sbcglobal.net>
Ken,
Ken Powell who I have shared info with about Deere PM alternators, but
the e-mail address is different.
engine.
when building experience with an unproven application like a Deere on
an airplane)
Yes with a Z-14, you just clost the crossfeed contactor to parallel the
batteries.
Deere voltage regulator lacked some needed "excitation"?
Yes. For experimentation I put a few short charges into the completely
dead battery and kept trying the pm alternator. The pm alternator would
not come alive until the dead battery was pretty much up to 12 volts.
This does not bother me as in normal use a dead battery would mean the
alternator has already failed and I have low voltage warning. Mostly I'm
mentioning it in regards to the recent thread where with other
architectures some guys are wiring their units to be able to come alive
with no battery voltage present.
in our application: We should find out "on a bench" that the Deere
system won't work with a dead battery.
I believe I have confirmed that. What does bother me is that the VR
failed while I was conducting the above scenario. I would like to
prevent that in the future as sooner or later I will miss a switch and
run the battery dead again. At home base I will charge it first but this
aircraft will fly to a number of remote locations. At least the VR
failed on rather than off. It seemed to run fine paralleled with the
crossfeed closed as long as I had the total system loads above the pm's
20 amp output.
this is a ground maintenance scenario.
Yes
PM alternator to some suitable landing spot, either "soon" or "procede
to final destination" (whatever my risk analysis and good judgement
and experience and prior planning for this scenario may indicate is
"safe enough")
This does not concern me at all. Loss of either of my systems is not a
show stopper for me and I don't believe it is a significant risk in any
event.
Quote: | . . I plan to have two batteries, so 2. would have to include loss of
BOTH batteries or some portion of the electrical circuit.
PM alternator system might stop putting out voltage and current if
battery power is lost?
Don't know. I donlt think one shorted cell would not stop it. I have
seen several flooded batteries open circuit in operation though and I
never even noticed til shutdown and subsequent restart attempt. I am not
confident that would happen with this regulator though because I don't
really know why it failed in this case. I am certain that it failed
before it was heavily loaded and before it had a chance to heat up
significantly. I suspect that it won't tolerate this scenario. Note that
my OVM cut off power into the VR but the VR still failed.
Ken Lehman
(haven't put my last name on a list in years other than in my address
but this list is pretty large now I guess)
David Carter
N6030X(at)DaveMorris.com Guest
Posted: Sun Sep 10, 2006 5:28 am Post subject: John Deere PM alternator regulator |
Many in the Corvair group (www.FlyCorvair.com) are using this same
John Deere generator/VR combo. You might take up the question there
and find out what people have witnessed. The guy who's probably
flown more hours with that combo than anybody is Gus Warren down at
William Wynne's hangar in Florida.
Dave Morris
At 07:38 AM 9/10/2006, you wrote:
Quote: |
>Ken,
>be Ken Powell who I have shared info with about Deere PM
>alternators, but the e-mail address is different.
>start engine.
>idea when building experience with an unproven application like a
>Deere on an airplane)
Posted: Wed Sep 13, 2006 6:21 pm Post subject: John Deere PM alternator regulator |
I can add one more interesting tidbit to this thread. Disconnecting the
Battery wire from the failed regulator does NOT stop the overvoltage.
I'm told it does stop the alternator output with a good regulator but it
does not do that on this failed unit.
Sounds similar to the automotive IR alternator where we also can not
guarantee that disconnecting the IGN wire will stop the alternator
output if the VR has already failed and is causing an overvoltage.
Ken
Dave N6030X wrote:
Quote: |
<N6030X(at)DaveMorris.com>
and find out what people have witnessed. The guy who's probably flown
more hours with that combo than anybody is Gus Warren down at William
Dave Morris
