jrichard(at)ccser.com Guest
Posted: Sun Jan 22, 2006 8:48 pm Post subject: Low amp draw battery master contactor..pulse interference |
Eric and Others..
The EV200 uses a pulsed coil energizer scheme to enable a low average
current draw to hold the coil in place. Normal aircraft contactors use DC
to close the coil then the same DC to hold the coil in place. I talked to
the Kilovac rep about the pulse circuit and he said they have had a few
complaints about interference from the pulsing. I'm not sure what kind of
interference, but I suspect conducted interference on the coil energizing
line spreading into other sensitive audio circuits.
Here's a web link to the EV200 PDF datasheet
http://relays.tycoelectronics.com/datasheets/ev200.pdf
Has anyone experienced this interference and does the normal filter scheme
for noisy loads published by 'lectric Bob take care of it?
John Richardson
Spokane WA
