eskflyer(at)lvcisp.com Guest
Posted: Fri Sep 15, 2006 6:49 pm Post subject: Factory help/ responce on fox 2 subbie install |
I have already made my own new improved large diameter lift struts and ends
beefed up the fuse . I talked to THE NEW WONDERFUL OWNERS of KITFOX and
will order the new thick spars and new inserts and use my old mounting
hardware and or make new to fit . The subbie is a ea81 with Cbox 2:62-1
reduction. . considering the vibrations and such that the 582 puts on this
front end at idle over the years i am replacing some of the smaller fuse
tubes in the front i havenot found any fatigued but with the heavier engine
Its my butt up there and I want to be safer than sorry.
Take care fly safe fly low fly slow
John Perry
kitfox 2 N718PD
582 / subbie soon
TD / straight floats
smokey_bear_40220(at)yaho Guest
Posted: Fri Sep 15, 2006 9:39 pm Post subject: Factory help/ responce on fox 2 subbie install |
Sounds better than the Storch I saw last week where
the builder was replacing the Rotax with an IO 290 and
no front structural changes???
Kurt S.
use my old mounting
of the smaller fuse
sorry.
John Perry
kitfox 2 N718PD
582 / subbie soon
