dean.psiropoulos(at)veriz Guest
Posted: Sun Jan 22, 2006 8:50 pm Post subject: MD200-306 VOR/ILS Indicator |
I have a VOR/ILS indicator made by Mid Content Instruments (MD200-306) and I
am trying to figure out if it is lighted internally or if I need to supply
some sort of lighting. The (Spartan) instruction manual shows lighting
connections but I'm not sure if they are for the annunciator lights or for
full facial lighting. Those who've used this instrument in your panels, do
you remember if it is internally lit or will I need to supply post lights or
something similar? I emailed Mid Content Instruments several days ago about
this but apparently their entire technical support department is on an
extended vacation! Thanks for all the help.
Dean Psiropoulos
RV-6A N197DM
Panel
nuckollsr(at)cox.net Guest
Posted: Sun Jan 22, 2006 9:14 pm Post subject: MD200-306 VOR/ILS Indicator |
At 11:50 PM 1/22/2006 -0500, you wrote:
<dean.psiropoulos(at)verizon.net>
I found a diagram calling out connections to the MD200-306 at
http://www.garmin.com/manuals/SL30Nav_Comm_FullStackWiring-TwoSL30SCH0103.pdf
Seems that 19, and 20 are 14 and 28v annunciator power.
23 and 24 are 14 and 28v dimmer for illumination. These
might be the same sources if you want the illumination and
annunciation to track.
Tim(at)MyRV10.com Guest
Posted: Sun Jan 22, 2006 10:07 pm Post subject: MD200-306 VOR/ILS Indicator |
Dean,
Hooked mine up a few weeks ago. The Annunciator lights are
the little words, like GPS, and NAV. Yes, you need to
put in a dimmer circuit for the backlighting. No post lights
needed. You give it the dimmer voltage at pin 23, and hook
pins 22 and 21 to ground. You won't use pin 25. You can
use all sorts of dimmers, but I used the $20 one from
Van's. Simple and works fine for the job, and I dim 3
other items with it as they are all fairly low draw.
Tim
Tim Olson -- RV-10 #40170
DEAN PSIROPOULOS wrote:
Dean Psiropoulos
RV-6A N197DM
Panel
jschroeder(at)perigee.net Guest
Posted: Mon Jan 23, 2006 8:37 am Post subject: MD200-306 VOR/ILS Indicator |
Dean -
We wired a lead from the dimmer buss to pin 23 of the MD200 (12 volt
system). Works fine to dim the instrument.
John
On Sun, 22 Jan 2006 23:50:12 -0500, DEAN PSIROPOULOS
<dean.psiropoulos(at)verizon.net> wrote:
and I
supply
Posted: Tue Jan 24, 2006 7:22 pm Post subject: MD200-306 VOR/ILS Indicator |
Thanks for all the info on the MD200-306 VOR/ILS Indicator lighting. I got a
little confused looking at the pinouts on the connector and there wasn't any
elaboration about it in the rest of the manual. But I figured the answers
could be found on the list. Where would I be without it!
Dean Psiropoulos
RV-6A N197DM
Panel
