n184da(at)volcano.net Guest
Posted: Tue Aug 29, 2006 6:45 am Post subject: Van's Wheel Fairings |
I am replacing (finally!) my original, old style wheel fairings, for Van's "new" Pressure Recovery fairings.Any ideas on what works best for a minimal tire-to-faring clearance around the lower opening?
Derrick L. Aubuchon
RV-4: N184DA (450+ hrs)
Jackson/Westover -Amador County (O70)
n184da(at)volcano.net (n184da(at)volcano.net)
dan(at)rvproject.com Guest
truflite(at)yahoo.com Guest
Dale Ensing
Posted: Tue Aug 29, 2006 10:01 am Post subject: Van's Wheel Fairings |
They have more rounded sides, front to back, with a taber toward the rear
that sort of reverses or becomes neutral at the trailing edge vs. the older
fairing which had more flat sides. Van made change in about 2000. New one
supposed to have less drag.
Dale Ensing
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
ronlee(at)pcisys.net Guest
Posted: Tue Aug 29, 2006 10:28 am Post subject: Van's Wheel Fairings |
At 11:37 AM 8/29/2006, you wrote:
Pardon my ignorance, but what is a pressure recovery
wheel pant as opposed to a regurlar wheel pant?
The old style are narrower. I doubt that you need to worry about
having the old style.
Ron Lee
c.ennis(at)insightbb.com Guest
Posted: Tue Aug 29, 2006 12:13 pm Post subject: Van's Wheel Fairings |
Derrick,
If you expect to fly from only asphalt and never have a tire low on pressure..a 1/4 inch around is enough.
If on the other hand you will be flying in the real world, 5/8 inch is the minimum side clearance I could stand. Front and rear of the tread I use 1 inch which allows most of the grass I pick up from my home field to exit without excessive buildup. Yes, I did start with 1/4 inch all around and increased the clearance from there.
Your results may vary.
Charlie Ennis N60CE
lsbrv7a(at)yahoo.com Guest
Posted: Tue Aug 29, 2006 12:24 pm Post subject: Van's Wheel Fairings |
I understand there is a high pressure area formed on the trailing portion of this shape that in effect recovers some of the pressure required to push the leading edge through the air.
I heard a story of a blimp with this shape collapsed the aft portion of the blimp when sufficient speed and recoverd pressure was obtained.
Dave Nellis <truflite(at)yahoo.com> wrote:
| Quote: | --> RV-List message posted by: Dave Nellis
Do not archive |
Sherman Butler
RV-7a Wings
Idaho Falls
Get your own [url= http://us.rd.yahoo.com/evt=43290/*http://smallbusiness.yahoo.com/domains]web address for just $1.99/1st yr[/url]. We'll help.
martin(at)gbonline.com Guest
Posted: Tue Aug 29, 2006 6:14 pm Post subject: Van's Wheel Fairings |
Derrick,
When I built my RV8 in 1999, I experimented with several wheelpant and tire variations. My objective was to obtain the most speed and the least drag possible. I found out that when I used any of the various cheap tires, I needed at least a 1/2 inch clearance around the tire casing, because when landing etc. the cheap tires would expand and rub the wheelpant. I solved the problem by installing Goodyear Custom III tires and tubes. The Custom III series has a much stiffer tred and side casing and holds its shape even with a hard landing. Note: the lower (closer to ground) you install the wheel pant, the faster you will go.
I tried Vans pressure recovery pants first and then went to Sam James pressure recovery pants because they went faster and looked better.
Good luck with your project.
Dick Martin
RV8 N233M
the fast one
1350 hours - it gets better every day
chaztuna(at)adelphia.net Guest
Posted: Wed Aug 30, 2006 4:08 am Post subject: Van's Wheel Fairings |
Dick
Two questions.
Can you recommend any other name brand tires besides Goodyear?
What speed gain did you see by using the Sam James wheel pants?
Charlie Kuss
[quote]Derrick,
Dick Martin
RV8 N233M
the fast one
Jerry Grimmonpre'
Joined: 09 Jan 2006 Posts: 144 Location: Huntley, Illinois 60142
Posted: Wed Aug 30, 2006 5:49 am Post subject: Van's Wheel Fairings |
Does anyone know the difference between Goodyear Custom III tires and the earlier Custom II tires?
Many thanks ....
Jerry Grimmonpre'
tcervin(at)valkyrie.net Guest
Posted: Wed Aug 30, 2006 4:10 pm Post subject: Van's Wheel Fairings |
I have Goodyear Custom II tires and they also maintain their shape.....stiff well made sidewalls.
Tom in Ohio RV6-A
Posted: Sat Sep 02, 2006 6:23 pm Post subject: Van's Wheel Fairings |
Charlie,
I used Goodyear because at the time they were readily available to me. I have not kept up with the airplane tire market, so I cannot recommend any other brand. I will say, however, that the performance and service life on my RV8 with the Goodyear Custom III has been excellent.
As near as I can tell, I gained about 5 knots with the Sam James wheel pants. I flight tested both pants and the James pants are faster.
Dick Martin
RV8 N233M
the fast one
Doug Gray
Joined: 10 Jan 2006 Posts: 112 Location: Sydney, Australia
Posted: Sat Sep 02, 2006 9:06 pm Post subject: Van's Wheel Fairings |
Gained 5 knots against which wheel pants from Vans? PR or the earlier
boxy ones.
On Sat, 2006-09-02 at 21:21 -0500, dick martin wrote:
| Quote: | Charlie,
excellent.
Dick Martin
RV8 N233M
Posted: Sun Sep 03, 2006 5:42 pm Post subject: Van's Wheel Fairings |
I had Vans later style round profile "pressure recovery" wheel pants, not
the old style
Dick Martin
RV8 N233M
the fast one
FLYaDIVE(at)aol.com Guest
Posted: Sun Sep 17, 2006 3:55 am Post subject: Van's Wheel Fairings |
In a message dated 8/29/06 10:16:43 PM Eastern Daylight Time,
martin(at)gbonline.com writes:
| Quote: | I tried Vans pressure recovery pants first and then went to Sam James
Dick Martin
RV8 N233M
Dick:
I can understand the looking better part. But, how much faster and how did
you determine that?
Barry
"Chop'd Liver"
Posted: Mon Sep 18, 2006 5:55 pm Post subject: Van's Wheel Fairings |
Barry,
I had Vans pants installed and flying first. I fitted Sam James pants and
flew them. Inorder to determine the performance, which appeared to be
faster, I reinstalled Vans pants and flew them and then removed them and
flew the Sam James pants an hour later. The James pants were approx 5 knot
faster +/- l knot..
Dick Martin
RV8 N233M
the fast one
