benson(at)mrsl.com Guest
Posted: Mon Sep 18, 2006 10:51 am Post subject: Wing skin crack |
Hello everyone,
I've been monitoring this list for several years now and have found it very
useful while building my -8QB. I have never felt the need to post anything
until now.
I received word that the owner/builder of an -8A in my local area,
(southwest Florida), has found a crack in the top skin of his left wing. The
plane has been flown approx. 500 hours and the crack is located just
outboard of the wing walk doubler, where the top skin is riveted to the rear
spar. Specifically, the crack has started where the top skin overlays the
doubler on the rear spar at the first rivet outboard of the doubler and has
propagated outboard through the next three rivets.
Has anyone else with higher time airframes noticed any skin cracks in this
area? Apparently the builder contacted Vans and they were unaware of any
problems from other builders and suggested that his skin might have
contained flaws in that area.
I am still several months away from final assembly and am wondering if I
should do anything to avoid this potential problem before I hang the wings.
Lonn Benson RV-8QB (#81666)
Osprey, Florida
Bob Collins
Joined: 11 Mar 2006 Posts: 427 Location: St. Paul, Minnesota
Posted: Mon Sep 18, 2006 4:22 pm Post subject: Wing skin crack |
I don't have the answer, but I do have a question. Why would someone wait on
a crack and watch it gobble up three rivets rather than stop drill it right
away?
Bob
Do Not archive
_________________ Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/ |
lifeofreiley2003(at)yahoo Guest
Posted: Mon Sep 18, 2006 5:15 pm Post subject: Wing skin crack |
I've seen this happen with holes not being deburred
before being dimpled. A slight tear can occur when the
dimple is set and then the crack can follow the line
of the rivets or take another direction. Also, an
incorrect matching angle issue from the rear spar to
the skin can cause excess stress.
Darrell Reiley
RV7A "Reiley Rocket"
N622DR Reserved
N469RV Reserved
CenTex_RV_Aircraft-owner(at)yahoogroups.com
khorton01(at)rogers.com Guest
Posted: Mon Sep 18, 2006 5:30 pm Post subject: Wing skin crack |
in this
of any
if I
the wings.
I've been a subscriber to the RV-List since 1997, and the Yahoo RV-8
list (and it predecessors) since it was first created. This is the
first report I can recall of a crack in any of the wing skins. I
think there was something unique about this situation. Either some
damage, or a builder error, or some other major event that caused
this. I wouldn't make any changes in this area. Trying to add more
material to beef up the structure may change the load paths, and put
more stress somewhere else. You could easily make more problems than
you solve.
Build on.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
chaztuna(at)adelphia.net Guest
Posted: Tue Sep 19, 2006 9:25 am Post subject: Wing skin crack |
It can also happen when the builder dimples directly on the pre-punched #42 size hole. If the hole is below #40 size, small micro cracks can be formed during the dimpling process. The same thing happens when dimpling #19 holes for #8 machine screws. When dimpling for a #8 screw, open the hole up to a #17 size drill. Ask me how I know this!
Charlie Kuss
[quote]--> RV-List message posted by: Darrell Reiley <lifeofreiley2003(at)yahoo.com>
Darrell Reiley
N622DR Reserved
N469RV Reserved
Email Forum -
- NEW MATRONICS WEB FORUMS -
http://forums.matronics.com
- NEW MATRONICS LIST WIKI -
http://wiki.matronics.com
- List Contribution Web Site -
jp_rv2001(at)yahoo.com Guest
Posted: Tue Sep 19, 2006 4:43 pm Post subject: Wing skin crack |
Section 5E of the -7 manual contains a caution about the potential for cracks to develop from pre-punched holes that are not match drilled... drilling removes shear marks left by the punch process.
"... removing the shear marks is important because if left alone, the skin can crack around the hole due to the stretching caused by the dimple dies. This cracking may not be apparent for several years after many hours of vibrations and flight cycles."
jp
Get your email and more, right on the [url=http://us.rd.yahoo.com/evt=42973/*http://www.yahoo.com/preview] new Yahoo.com[/url] [quote][b]
Posted: Thu Sep 21, 2006 6:20 am Post subject: Wing skin crack |
Search the archives on 'match drill' and you will find there have been several lengthy discussions about this (March '04 and April '02, etc.)... in my mind there is a connection, in the mind of others there may not be.
I will use my judgement, you will use yours... Perhaps this is why i am committed to building my own RV rather than buying one from somebody else.
jp
jjessen
Posted: Thu Sep 21, 2006 7:43 am Post subject: Wing skin crack |
I've matched drilled and deburred and dimpled and I still don't see a smoothness around the hole. I often see little nibbles or some such thing. Not cracks, but it does make me wonder if I'm doing things correctly. Should be smooth, should it not?
John Jessen
#40328
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jim Peoples
Sent: Thursday, September 21, 2006 7:20 AM
To: rv-list(at)matronics.com
Subject: RE: Wing skin crack
jp
Hopperdhh(at)aol.com Guest
Posted: Fri Sep 22, 2006 5:23 am Post subject: Wing skin crack |
John,
Like you, I have looked closely at the holes after dimpling, and see a roughness -- even though the holes were deburred before dimpling. For sure, a smaller hole would be more likely to have stress cracks after dimpling than a bigger hole, so no. 40 is the right drill to use, not 41 as some have done, or no drill at all.
Maybe the best thing to do is to deburr the hole AFTER dimpling. But many airplanes have been built without doing this and none (that I know of) have fallen out of the sky due to skin cracks. Aluminum does fatigue and eventually all of the RV's will start cracking! Maybe in 50,000 hours?
Dan Hopper
RV-7A
In a message dated 9/21/2006 11:45:52 A.M. Eastern Daylight Time, jjessen(at)rcn.com writes:
| Quote: | I've matched drilled and deburred and dimpled and I still don't see a smoothness around the hole. I often see little nibbles or some such thing. Not cracks, but it does make me wonder if I'm doing things correctly. Should be smooth, should it not?
John Jessen
#40328
jp
="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
.matronics.com/">http://forums.matronics.com
ronics.com/">http://wiki.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
jjessen
Posted: Fri Sep 22, 2006 7:25 am Post subject: Wing skin crack |
Just makes one a little quizzical after all the preparation, but something has to happen with the deformation.
John Jessen
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Hopperdhh(at)aol.com
Sent: Friday, September 22, 2006 6:22 AM
Subject: Re: Wing skin crack
John,
Dan Hopper
RV-7A
John Jessen
#40328
jp
