923te(at)cox.net Guest
Posted: Tue Sep 19, 2006 7:15 am Post subject: PowerFLow |
Since Powerflow has been brought up again I thought I would comment.
I am quite curious how PowerFlow got thru the STC process seeemingly so easily....
Compared to what trouble the FAA is giving Gary with a far better cowl than available anywhere for our grummans.
I guess once you have worked with the FAA for several years and acheived several STC's they cut you some slack
I am suspicious that the short stack approval process did not check out a lot of things....like the effects to air flow and cooling by interrupting the exit ramp flow or the additional heat gain inside the cowl which I think has shortened a few owners battery life.
Things I wish were addressed now that I bought into the short stack.
Just venting and hoping Gary's cowl gets approved soon...hang in there Gary and don't let those FAA weenies stop you.
Ned
| - The Matronics TeamGrumman-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?TeamGrumman-List |
FLYaDIVE(at)AOL.COM Guest
Posted: Tue Sep 19, 2006 2:40 pm Post subject: PowerFLow |
In a message dated 9/19/06 11:17:25 AM Eastern Daylight Time, 923te(at)cox.net
writes:
Quote: | Since Powerflow has been brought up again I thought I would comment.
easily....
than
the
Quote: | exit ramp flow or the additional heat gain inside the cowl which I think
has
Gary
Quote: | and don't let those FAA weenies stop you.
Ned
"Green Paper makes for a Slippery Runway"
Barry
"Chop'd Liver"
