RE : Re: Rear wing spar question - shimming
Carlos Sa
PostPosted: Mon Jan 23, 2006 9:06 am    Post subject: RE : Re: Rear wing spar question - shimming Reply with quote
Shimms are ok up to 3 mm, more than that and you should "consult the designer" (from the old HD construction manual, page 12).
Carlos
CH601-HD. Left tank done, right tank in progress.
michael: I found a use for adding a few aluminum shims in several places durning the build. I believe I used a couple just where you are having the problem . Jack in Los Osos CA
Michael Valentine wrote:
Hello again everyone...
I have just attached my rear spar to the back of the rear ribs and it
is clear that it is not straight.
Jack Russell -Clovis CA
601 XL Jabiru 3300
Progress update at:
http://www.geocities.com/clojan(at)sbcglobal.net/zodiacbarn.html
CH601-HD, plans
Montreal, Canada
