Posted: Sat Sep 23, 2006 5:10 pm Post subject: HID lights |
Tim and others with DW installed,
Do the DW lights light up well enough for you? My original idea was to use the DW for ldg and the Van’s ldg light kit for taxi. I’m at a point that I can forego the Vans kit but would like some field research on how well the DW lights do with one pointed for ldg and one pointed for taxi.
Rob Wright
#392
Wingtips
Tim(at)MyRV10.com Guest
Posted: Sat Sep 23, 2006 6:12 pm Post subject: HID lights |
Well, this might not be exactly what you're looking for but....
I've got 2 Duckworks HID's. From the time that I've installed them,
I haven't gotten around to properly aiming them. Right now they
are way too low, maybe 30' in front of the plane or so...not
what you'd necessarily want for night landings. But here's the
big "however". HOWEVER, with those HID's, even with them so
mis-aimed that they really shouldn't be too good, they are so
darn bright that they are much better than my old plane that
had 2 100W halogen standard aviation lamps in it, or the single
250W that it originally had. One of these days I'll get around
to aiming them a bit further forward, and based on what I'm seeing
now, I think it will really be impressive. I'm not really one
who cares for separate landing and taxi lights, but I think if
you aimed one for taxi, it will still be plenty of help for
landing. The coolest part about the HIDs isn't even the
brightness....it's the fact that my ammeter only goes up by
6A when both are lit up!
Rob Wright wrote:
| Quote: | Tim and others with DW installed,
Rob Wright
#392
Wingtips
Posted: Sat Sep 23, 2006 6:35 pm Post subject: HID lights |
Thanks.
Rob
wayne.e(at)grandecom.net Guest
Posted: Sun Sep 24, 2006 4:39 am Post subject: HID lights |
Rob,
I installed the DW HID's but I'm not flying yet, so can't comment on coverage. But I went ahead and installed Van's also because I wanted to have the ability to install a Wig Wag system to allow me to flash my lights (wig wag) when I'm coming in to land. The fellow at DW told me I couldn't WigWag the HID's so I will use the Van's lights for that.
Wayne Edgerton #40336
LarryRosen
Posted: Sun Sep 24, 2006 5:01 am Post subject: HID lights |
I have already installed Vans lights, but after reading on VAF about
light coverage and working on my electrical load analysis, I have
decided to add one DW HID light for landing and use the Vans lights for
taxi.
Larry Rosen
RV-10 #356
http://lrosen.nerv10.com
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Posted: Sun Sep 24, 2006 12:32 pm Post subject: HID lights |
Yeah, that's my original plan. I thought I could adapt Bill VonDane's LED
Nav lights for installing sideways but they just don't put out the light in
that orientation. So now I working on converting my hardware to the ldg
light/nav light combo and I'll put my strobe heads in by themselves.
In this case I'm measuring about 6 times before I cut (hopefully) once!
Rob Wright
#392
Wingtips
