Nick(at)Scholtes1.com Guest
Posted: Tue Sep 26, 2006 10:22 am Post subject: Issues with Dual Brakes |
KitFoxers,
I've been looking to buy a KitFox for a while now, and am in the process
of educating myself and also starting to make appointments to look at
airplanes.
I want the airplane to have brakes on both sides, as I plan to have some
students fly left seat in the airplane. I've talked to several folks
who are selling their KitFoxes, and a common comment is, "I originally
had brakes on both sides, but I removed them from the right side because
there was a problem with them."
Could someone educate me on what the problem is, and more specifically,
is there a solution to it?
If I were to buy a KitFox that only had brakes on the left side, and I
wanted to install brakes on the right side, what special information do
I need to know to get a dual-brake system that really works? Where
would I get the parts, and approximately how much would everything cost?
Any advice would be appreciated.
Best Regards,
Nick Scholtes
Michel
Posted: Tue Sep 26, 2006 10:54 am Post subject: Issues with Dual Brakes |
On Sep 26, 2006, at 8:22 PM, Nick Scholtes wrote:
| Quote: | If I were to buy a KitFox that only had brakes on the left side, and I
do I need to know to get a dual-brake system that really works?
Without being able to answer your question, Nick, here are my thoughts
about dual brakes.
My model 3 has brakes only on the left side. I started flying it, first
with my instructor. I sat on the left seat. Then my son started with
the instructor. He sat on the left seat. Then I went flying with my
son. He sits on the left seat. In the air, we fly on turns. It is very
pleasant.
But it is always the left-seater who lands the plane. I tried once to
land from the right-hand seat and ... it was scary! Then my son and I
have a rule: While I fly much more than him, if anything happens in
form of an emergency, the left-seater is the PIC and the right-seater
is only doing what he is instructed to. It's a question of safety, no
time to fight about who does what.
The bottom line? I don't need brakes on the right hand seat since I
don't know what it will be used for. Are you sure you want to add the
extra weight and complication?
cheers,
Michel
Lynn Matteson
Posted: Tue Sep 26, 2006 12:05 pm Post subject: Issues with Dual Brakes |
Nick-
I haven't found the brakes to be any problem at all, through the 20-odd
hours of flying dual with my instructor, then the 80-odd hours of solo
since then. Of course, solo doesn't allow for the right-side brakes to
get the used much. I am flying a model IV, with Matco calipers and
Cleveland master cylinders. My brakes will even hold the plane at
full-throttle run-up during a short-field takeoff, but then I'm running
an 85-hp Jabiru with a cruise prop. : )
So you gotta ask yourself....is is the brakes REALLY working, or is it
that Jabiru/prop combo NOT working?
Lynn
On Tuesday, September 26, 2006, at 02:22 PM, Nick Scholtes wrote:
KitFoxers,
process of educating myself and also starting to make appointments to
look at airplanes.
some students fly left seat in the airplane. I've talked to several
folks who are selling their KitFoxes, and a common comment is, "I
originally had brakes on both sides, but I removed them from the right
side because there was a problem with them."
specifically, is there a solution to it?
do I need to know to get a dual-brake system that really works? Where
cost?
Best Regards,
Nick Scholtes
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
dgolden(at)golden-consult Guest
Posted: Tue Sep 26, 2006 12:33 pm Post subject: Issues with Dual Brakes |
Lynn Matteson wrote:
Nick-
Lynn
There was a problem with the Matco brake masters if BOTH right and left
pilot brakes were applied at the same time. This could result in a
complete lockup of the brakes. There was a simple fix made available by
Matco and Skystar. This was brought up on this list in the last week or
so. Check: http://www.carttonic.com/files/file_download.php?fi_id=38522
Dennis
| Quote: | >
> KitFoxers,
> look at airplanes.
> Best Regards,
> Nick Scholtes
Dennis Golden
Golden Consulting Services, Inc.
ddsyverson(at)comcast.net Guest
Posted: Tue Sep 26, 2006 12:35 pm Post subject: Issues with Dual Brakes |
Nick,
A couple ideas to think about, from a guy who bought (parts of) a model 7
Trigear and ordered the dual brakes.
1) There is a difference between the trigrear and the tailwheel version -
Tailwheel, you can steer on the ground from the right seat with the linkage
to the tailwheel even without brakes - Trigear - no such thing - all you have
on the ground with the trigrear for directional control (since it is not
connected to the pedals) is the throttle and rudder - you can't steer with
brakes you don't have on the trigear from the right seat. If you get the
tailwheel - you definily have an option from the right seat without brakes.
2) How much do you trust students? Maybe a point to consider together with
item 1 above and some of those cluttered, busy and congested ramps we
sometimes get dragged into against our will. Even a composite propeller will
chew through aluminum and other stuff that some airplanes and gas pumps are
made of.
3) Familiar with the concept? - have something I didn't need vs need something
I don't have (like carb heat, brakes, etc...) Maybe I am just paranoid...I
don't know.
Just a couple thoughts; however, it is pretty clear also that people fly
kitfoxes in all kinds of configurations.... successfully
Also - a Kitfox should make a pretty good trainer - light enough on the
controls and you need to use the rudder - two things that really help a a new
person learn to feel what they are doing with the airplane.
FYI - the first and only airplane I flew where the instructor was denied the
benefit of brakes with me in the left seat was a Piper Arrow - that seemed
to touchdown at a somewhat higher speed than a kitfox, but it did have the
benefit of an interconnect with the front training wheel.
Sincerely,
Dave S
St Paul, MN
M-7 Trigear
DO NOT ARCHIVE
On Tuesday 26 September 2006 1:22 pm, Nick Scholtes wrote:
KitFoxers,
airplanes.
Best Regards,
Nick Scholtes
kirkhull(at)kc.rr.com Guest
Posted: Tue Sep 26, 2006 12:45 pm Post subject: Issues with Dual Brakes |
Some instructors will not fly in a tailwheel with out right brakes.
clint_bazzill(at)hotmail. Guest
Posted: Tue Sep 26, 2006 2:25 pm Post subject: Issues with Dual Brakes |
I have a Model IV Kitfox with brakes on both sides. Works just great. Have
about 1150 hours on plane. Over 1050 from the right seat. Clint
Subject: Re: Issues with Dual Brakes
Date: Tue, 26 Sep 2006 14:46:24 -0500
Nick,
have
made of.
something
don't know.
new
Sincerely,
Dave S
St Paul, MN
M-7 Trigear
DO NOT ARCHIVE
> KitFoxers,
> airplanes.
> Best Regards,
> Nick Scholtes
dave
shilocom(at)mcmsys.com Guest
Posted: Tue Sep 26, 2006 5:23 pm Post subject: Issues with Dual Brakes |
The left and right seat thing is purely personal training and preference.
It is just as natural for me from the left or the right. My fox has brakes
on both sides for instructional purposes. Many brave instructors do it
without breaks, but not me. I quite often take Young Eagles rides from the
right seat. Some of the older kids like to play pilot. Bob U.
