n8vim(at)arrl.net Guest
Posted: Fri Sep 29, 2006 8:40 am Post subject: Finish kit for alternative engine |
Hey y'all!
Van's finish kit is listed for "I/O-540 Lycoming engines only".
My question is: What would I need to add/drop from the "finish kit" if I
want to use an Egg Subaru?
Thanks!
-Jim 40384 (Still on bottom wing skins)
Rick S.
Posted: Fri Sep 29, 2006 9:36 am Post subject: Finish kit for alternative engine |
James.
The only thing in the finish kit I have found to be Lycoming specific is the engine mount, spinner and the cowl. Be advised the nose strut mounts to the engine mount so that's some engineering left for you to figure out. The firewall forward kit is almost ALL Lycoming specific though.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
LloydDR(at)wernerco.com Guest
Posted: Fri Sep 29, 2006 10:39 am Post subject: Finish kit for alternative engine |
With your Eggenfellner FWF kit, you will get the main engine mount, but
will still need the nose wheel strut and attaching hardware. Depending
on the cowl you choose, the standard from Vans, or the James cowl from
Eggenfellner. Everything else is still the same so far.
Give me a call directly and we can discuss it, as I have the list of
what I left out at home.
Dan Lloyd
RV10E
(N289DT)
