		lhelming(at)sigecom.net Guest
				 Posted: Fri Jan 27, 2006 8:00 pm    Post subject: mogas |
				What is easy way to determine which airports have autogas aka mogas for planning XC stops?
 Indiana Larry, RV7
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Painless
  Joined: 10 Jan 2006 Posts: 40 Location: Peshtigo, Wisconsin
				 Posted: Fri Jan 27, 2006 8:24 pm    Post subject: mogas |
				Check out  www.airnav.com
 Type in the airport identifier(s) that you need and it will list sevices at
 each in regards to what fuel is available, as well as fairly current prices.
 Jeff Orear
 RV6A  N782P  (reserved)
 Getting close
 Peshtigo, WI
  _________________ Jeff Orear
RV6A  N782P
Peshtigo, WI |
		bhester(at)hopkinsville.n Guest
				 Posted: Fri Jan 27, 2006 10:04 pm    Post subject: mogas |
				It will also let you say what type fuel you are looking for and show all
 airports within so many miles of a specific airport. You should also
 call ahead to insure the info is current. We use to have it but no
 longer do. I think the info still says we do. I know two airports not
 far from here that has it. Murray, KY and Springfeild, TN
 Surfing the Web from Hopkinsville, KY
 Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/
 RV7A Slowbuild wings-QB Fuse-XPO360 engine
 Jeff Orear
 Getting close
 Peshtigo, WI
		DOUGPFLYRV(at)aol.com Guest
				 Posted: Sat Jan 28, 2006 4:43 am    Post subject: mogas |
				AIRNAV.COM
 DO NOT ARCHIVE
		Ed Anderson
				 Posted: Sat Jan 28, 2006 5:01 am    Post subject: mogas |
				Larry, AirNav.Com has a Fuel Price program.  You can use it several ways.
 But, it also  includes a function that enables you to input your departure
 and arriving airport and specify either the fastest or cheapest route.  You
 can also specify some parameters such as max leg distance, etc.  It will
 then compute up to 10 routes and give you how much you would save (I presume
 over the average price along the route) each route as well as the distance
 of each route, etc.
 Worth using, but as others have said, sometimes the fuel prices and
 availability are not up todate so you should call ahead.
 Ed A
 Ed Anderson
 Rv-6A N494BW Rotary Powered
 Matthews, NC
 eanderson(at)carolina.rr.com
  _________________ Ed Anderson
Matthews, NC
eanderson@carolina.rr.com |
		Charles Heathco
				 Posted: Sat Jan 28, 2006 9:37 am    Post subject: mogas |
				I have not been able to find Mo-gas on trips, I just settle for 100LL Lean her out and try to burn off the lead before you park it, Charlie Heathco
		rv8ch
				 Posted: Sat Jan 28, 2006 10:15 am    Post subject: mogas |
				 	  | Quote: | 	 		   I have not been able to find Mo-gas on trips, I just settle for 100LL
  Heathco
 If you normally run mogas but you have to run 100LL when
 mogas is not available, you could put a little "lead scavenger"
 in with the 100LL.  Here's a good one:
   http://www.aircraftspruce.com/catalog/appages/Decalin.php
 Mickey Coggins
 http://www.rv8.ch/
 #82007 finishing
  _________________ Mickey Coggins
http://www.rv8.ch/ |
