jakent(at)unison.ie Guest
Posted: Sun Oct 01, 2006 12:30 am Post subject: Brass bolt for firewall ground. |
Why not get a bit of brass rod and use a �-28 (or whatever) die on it? Some old toilet cistern ball-cocks had brass rods….. Completely free if you can find a dead one! John Kent RV-4 EI-DIY.
icubob(at)newnorth.net Guest
Posted: Sun Oct 01, 2006 2:48 am Post subject: Brass bolt for firewall ground. |
in the past 2 days i ordered an extra 5/16 brass bolt from b and c. also some extra star washers. they will split up anything they sell and sell an individual part. bob noffs
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Mon Oct 02, 2006 5:57 am Post subject: Re: Brass bolt for firewall ground. |
Instead of using a brass or copper bolt, consider using a U-shaped bar of copper that is slipped in like a paper clip or bobby-pin. That way the fixturing and current conducting functions are separated. If this were on the edge of the firewall, no hole through the firewall might need to be made.
"The man who carries a cat by the tail learns something that can be learned in no other way." - Mark Twain
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
N6030X(at)DaveMorris.com Guest
Posted: Mon Oct 02, 2006 6:25 am Post subject: Brass bolt for firewall ground. |
Eric, I can always identify your posts without even looking at the
signature line, because they are so refreshingly outside the
box. But I can't picture what you mean here. Can you explain
further where the U is slipped into?
Dave Morris
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
http://forums.matronics.com/viewtopic.php?p=65176#65176
