debrun26(at)juno.com Guest
Posted: Thu Sep 28, 2006 10:27 pm Post subject: Kitfox 5 1400 Gross Weight |
I just bought a KF5 with a gross of 1400lbs. It was built in 1998 and I understand many other series 5's have a gross of 1550 lbs. Is there any structural difference between the two? Is there a way I could have mine bumped up to 1550 lbs? Layne
________________________________________________________________________
Visit http://www.juno.com/value to sign up today!
ddsyverson(at)comcast.net Guest
Posted: Fri Sep 29, 2006 12:56 pm Post subject: Kitfox 5 1400 Gross Weight |
Layne,
There are at least two things that make the 1550 gross that I am aware of. 1)
The thickness of the spar tubes. (0.065" for the 1550 vs 0.058" for the
lighter spar tubes.) 2) The bolts which fasten fasten the lift strut brackets
to lift struts - for the 1550 they are NAS standard which is distinguished by
a dished top on the bolt head - if the bolt heads are not dished - they are
not NAS. There may be other differences - I AM NOT SURE ABOUT OTHER
DIFFERENCES. I would go completely through the paperwork for the airplane and
try to figure out what spec this bird was designed to. Another deal you could
work is check the list archives - this subject has been up before.
Another point - if the aircraft was registered as 1400 - that is your legal
limit, unless it is amended.
If in doubt, you already know what to do.
Sincerely,
Dave S
St Paul, MN
M-7 nose dragger
On Friday 29 September 2006 1:25 am, debrun26(at)juno.com wrote:
| Quote: | I just bought a KF5 with a gross of 1400lbs. It was built in 1998 and I
jdmcbean(at)cableone.net Guest
Posted: Fri Sep 29, 2006 6:05 pm Post subject: Kitfox 5 1400 Gross Weight |
First thing to check is the spar wall thickness. Give me a shout at john(at)kitfoxaircraft.com (john(at)kitfoxaircraft.com)
<![if !supportEmptyParas]> <![endif]>
AUTOTEXTLIST \s "E-mail Signature" <![endif]-->Fly Safe !!
John & Debra McBean
208.337.5111
www.kitfoxaircraft.com
"It's not how Fast... It's how Fun!"
<![endif]--><![if !supportEmptyParas]> <![endif]>
-----Original Message-----
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of debrun26(at)juno.com
Sent: Friday, September 29, 2006 12:25 AM
Subject: Kitfox 5 1400 Gross Weight
Visit http://www.juno.com/value to sign up today! [quote]<![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]> - The Kitfox-List Email Forum - --> - NEW MATRONICS WEB FORUMS - --> - NEW MATRONICS LIST WIKI - --> - List Contribution Web Site - Thank you for your generous support! -Matt Dralle, List Admin. --> <![if !supportEmptyParas]> <![endif]>[b]
kitfox(at)ida.net Guest
Posted: Sat Sep 30, 2006 7:25 am Post subject: Kitfox 5 1400 Gross Weight |
There is a kit manufacture date you can check. I recieved mine in 96 and it is a 1400 lb. not to long after that they switched to the 1500 lb. When I talked to Skystar about the upgrade they told me it was a spar carry through tube and area that was the major change. It was thicker and there was no way to up the gross on it. I did not chase any details after that. The only thing for sure is the kit manufacture date for the 1400 to 1500. Not much help. Good luck
Albert
5TD-NSI-T
janderson412(at)hotmail.c Guest
Posted: Sat Sep 30, 2006 1:02 pm Post subject: Kitfox 5 1400 Gross Weight |
My kit left the factory Nov 96 and is 1550 MAUW. My lit said spar
carry-through tube upgrade and spar wall thickness as I remember.
Subject: Re: Kitfox 5 1400 Gross Weight
Date: Sat, 30 Sep 2006 09:25:24 -0600
help. Good luck
Albert
5TD-NSI-T
Need more speed? Get Xtra Broadband (at)
http://jetstream.xtra.co.nz/chm/0,,202853-1000,00.html
jimlc(at)att.net Guest
Posted: Sat Sep 30, 2006 10:26 pm Post subject: Kitfox 5 1400 Gross Weight |
At the suggestion of Skystar to upgrade my plant to 1450, I purchased the heavier tubes, the stronger bolts, and added a plywood gusset to the triangle tubing of the lower fuselage where it accepts the load from the wings. At the time they thought that would do it.
Jim Crowder
At 09:25 AM 9/30/2006, you wrote:
[quote]There is a kit manufacture date you can check. I recieved mine in 96 and it is a 1400 lb. not to long after that they switched to the 1500 lb. When I talked to Skystar about the upgrade they told me it was a spar carry through tube and area that was the major change. It was thicker and there was no way to up the gross on it. I did not chase any details after that. The only thing for sure is the kit manufacture date for the 1400 to 1500. Not much help. Good luck
Albert
5TD-NSI-T[b]
Posted: Sat Sep 30, 2006 10:51 pm Post subject: Kitfox 5 1400 Gross Weight |
Hmm, my data says 1550lbs?? Everyone seems to be quoting 1500, am I correct
at the former?
Date: Sun, 01 Oct 2006 00:25:37 -0600
Jim Crowder
help. Good luck
Albert
5TD-NSI-T
Read the latest Hollywood gossip (at) http://xtramsn.co.nz/entertainment
Posted: Sat Sep 30, 2006 11:11 pm Post subject: Kitfox 5 1400 Gross Weight |
Oops. I should have said "to upgrade my plane to 1550lbs.
Jim Crowder
At 12:25 AM 10/1/2006, you wrote:
[quote]At the suggestion of Skystar to upgrade my plant to 1450, I purchased the heavier tubes, the stronger bolts, and added a plywood gusset to the triangle tubing of the lower fuselage where it accepts the load from the wings. At the time they thought that would do it.
Jim Crowder
| Quote: | There is a kit manufacture date you can check. I recieved mine in 96 and it is a 1400 lb. not to long after that they switched to the 1500 lb. When I talked to Skystar about the upgrade they told me it was a spar carry through tube and area that was the major change. It was thicker and there was no way to up the gross on it. I did not chase any details after that. The only thing for sure is the kit manufacture date for the 1400 to 1500. Not much help. Good luck
Albert
5TD-NSI-T | [b]
Posted: Sun Oct 01, 2006 8:52 am Post subject: Kitfox 5 1400 Gross Weight |
That would be about the right date. Mine was early in 96 Just seconds before
the upgrade. My typical luck.
Albert
JJProbasco(at)cs.com Guest
Posted: Mon Oct 02, 2006 6:27 pm Post subject: Kitfox 5 1400 Gross Weight |
Mine is a 1995 S5 kit. It came with .058 wall spars. When I asked SkyStar about the upgrade to 1550#, all they recommended was .065 wall spars and a NASA grade bolt for the lift strut to fuse attachment. No mention of heavier carry through tubes or fuse reinforcement. Sky star proceeded to accept my return of .058 spars and replaced them with the .065 ones for a very nominal charge. It seems the .058 ones were getting hard to procure for the two place Kitfox Lite.
Jeff [quote][b]
