N6030X(at)DaveMorris.com Guest
Posted: Mon Oct 02, 2006 8:02 am Post subject: battery cables & Relays 'G's" skunk stink |
Anybody have a centrifuge with accelerometer and want to conduct a
little experiment?
Dave Morris
At 10:07 AM 10/2/2006, you wrote:
I think it is time for someone with a little authority to clear this
up. My authority is so little that I have hidden it under one of the
periods in this posting. A prize awaits the one who finds it.
1) Relay mounting. Type 70 Stancor Rodgers White Emerson Tyco. See:
http://www.alliedelec.com/Images/Products/Datasheets/BM/STANCOR/Stancor_Industrial-Control_5760005.pdf
So the manufacturer says, "mount plunger vertical, cap down". I
checked into the engineering data on this part and of course the
corporate conglomeratization has destroyed the engineering knowledge
that built the part. The manufacturer PROMISED they'd get back to
me.....It's not DO-160 bubela. And it's only 122 deg F max operating
temp. Etc. etc. Use the Kilovac EV200 part if you can.
(Yes, I am selling my Powerlink Jr. III now and I am MONTHS late.)
2) G-forces: [CAUTION-Head May Explode] Jacob Rabinow's Law (not
that he called it that...). Gracefulness is "when the first, second,
and third derivatives of the equation of motion monotonically and
simultaneously go to zero." Which is to say--when the velocity,
acceleration and impulse (the change in acceleration) smoothly and
So many mysteries--a gyro will be ruined if placed on a workbench
hard enough to be audible, but will do fine in an airplane doing
aerobatics or combat. A pencil held horizontal and dropped 12 inches
experiences G-forces that will destroy an airplane and kill a pilot.
Curtis mercury-type elapsed-time meters were 12G-rated but failed if
dropped on a workbench.
Motion is composed of displacement, velocity, acceleration and
impulse elements. The stiffness of a system determines which of
these can be ignored in any practical application. Designers and
engineers have the job of measuring some of these elements and
constraining the system to prevent the others from becoming
critical. This has other physical science analogues too.
The exercise is left for the student.
"Everything you've learned in school as "obvious" becomes less and
less obvious as you begin to study the universe. For example, there
are no solids in the universe. There's not even a suggestion of a
solid. There are no absolute continuums. There are no surfaces.
There are no straight lines."
- R. Buckminster Fuller
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
http://forums.matronics.com/viewtopic.php?p=65198#65198
nuckollsr(at)cox.net Guest
Posted: Mon Oct 02, 2006 8:08 pm Post subject: battery cables & Relays 'G's" skunk stink |
At 05:09 PM 10/2/2006 +0000, you wrote:
Hello Eric
You wrote:
"So the manufacturer says, "mount plunger vertical, cap down"
I have never taken apart or looked very close at the relay that is being
talked about.
See:
http://www.aeroelectric.com/Pictures/Contactors/S701-1a.jpg
http://www.aeroelectric.com/Pictures/Contactors/S701-1b.jpg
http://www.aeroelectric.com/Pictures/Contactors/S701-1c.jpg
http://www.aeroelectric.com/Pictures/Contactors/S701-1e.jpg
http://www.aeroelectric.com/Pictures/Contactors/S701-1f.jpg
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
