Dennis Johnson
Posted: Mon Oct 02, 2006 7:34 am Post subject: Connectors vs. Straight Wire |
Greetings,
The entire instrument panel on my Lancair Legacy I'm building is attached to the airframe with only four bolts and is therefore relatively easy to remove in one large piece. That is, mechanically easy to remove, if it weren't for a bazillion wires connecting it to the airframe. On the other hand, the Legacy has a front hinged canopy and a removable glare shield, which provide reasonably good access to the rear of the instrument panel while it is in place.
I can either run the wires from the airframe directly to the various components on the panel or I can insert D-Sub connectors between all the wires and the instrument panel. If I use connectors, it will make removing the instrument panel easier for repairs or upgrades. Running the wires directly to the panel, without connectors, will reduce the parts count but make future service more difficult.
I'm torn between the two alternatives. My first thought was to add connectors to every wire in the expectation that I'll almost certainly want to remove the instrument panel at some point in the future for troubleshooting, repairs, or upgrades. Working on the panel while it's on my workbench is soooooo convenient. But there are tons of wires, many of them shielded, and running every single one of them through a connector is a big project. Considering that I have reasonable access to the rear of the panel with the canopy open and the glareshield removed, should I just plan to service the panel with it in place? Anybody who's "been there, done that" have any advice?
Dennis Johnson
Lancair Legacy; painting done, still wiring the panel
aadamson(at)highrf.com Guest
Posted: Mon Oct 02, 2006 1:09 pm Post subject: Connectors vs. Straight Wire |
Dennis.
I might be late with this comment.... But Cannon Plugs, Cannon Plugs, Cannon Plugs..... Did I say Cannon Plugs?
You can get them in various densities. I'd try to keep it to 3 or 4 and group things together in logical sense.
I know you can get them Lancair, or there are probably other sources as well. I've not gone there yet, but when I do, it will be Deutch connectors and Cannon plugs you can be assured.
Also, heat-shrink labelers are pretty cheap and are available on ebay to help keep things grouped and sorted and labeled.
Alan
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dennis Johnson
Sent: Monday, October 02, 2006 11:34 AM
Subject: Connectors vs. Straight Wire
Greetings,
Dennis Johnson
Dennis Johnson
Posted: Mon Oct 02, 2006 4:26 pm Post subject: Re: Connectors vs. Straight Wire |
Hi Alan,
Thanks for the reply to my question about connectors to allow removing the instrument panel. You suggested Cannon plugs. It seems to me that Cannon plugs are more expensive and less convenient to install than D-Sub connectors. I hope there's not a fundamental problem with D-Subs because nearly every electronic component I installed came with D-Subs on the back.
Best,
Dennis
Posted: Mon Oct 02, 2006 5:05 pm Post subject: Connectors vs. Straight Wire |
Oh, I think they would work ok... Except, I had one bad experience. I had a
monitor with a 15pin D-Sub on it. It worked for a couple of years and then
all of a sudden it started to flake out... I found that the "tension" on the
female pins started to fail. I would have to "cock" the connector in order
that the colors on the monitor appeared correct. Finally, it just wouldn't
take any jiggling to get the colors right and I had to buy a new monitor.
YMMV, but there are lots of kinds of Cannon plugs, and it's a one time
investment. For something like interconnects that have to survive in
"hostile" environments, its just my preference, but I'll use cannon plugs.
Good luck btw, can't wait to see yours sometime ...
Alan
stein(at)steinair.com Guest
Posted: Mon Oct 02, 2006 5:26 pm Post subject: Connectors vs. Straight Wire |
My comment will probably be a little different from the typical..but, I'd push you to do as much straight wiring as possible. On my 1st plane I did the Canon Plug thing all over the place.....have you ever tried to troubleshoot an electrical gremlin through a bunch of canon plugs or D-Subs? It's a pain in the rear. Once you add hundreds of pins, that's hundreds of new joints that are potential future problem areas.
Next, why do you really need them? Sure, it sounds like a great idea, but really....how many times do you actually take a panel in and out of plane? As far as individual components, it only takes a couple screws to drop out any of the EFIS's out there, radios slide out of trays, etc..., so you don't get much advantage there. Next, even if you wanted you shouldn't run everything through canon plugs. Audio Wires specifically can get really touchy running them through connectors...all the headset, mic, aux leads are/should be shielded and breaking that shield just creates another area for noise and more gremlins to move in. You can't shouldn't split EGT/CHT wires, nor some other sensor wires along with the heavy wires. Basically, it looks good at airshows and in magazines, but the truth of the matter is it's almost impossible to get by NOT hooking some things directly to your panel anyway and then there you are with a bunch of nice looking canon plugs, then you Still have to remove things from the panel anyway....point is no matter what your intentions you'll still probably have a bunch of stuff hooked directly to the panel anyway (pitot tubing, static tubing, maybe some antennas, fat battery wires, 02 lines if you have them, "P" leads which shouldn't be broke, air vents lines, push/pull cables, so on and so forth).
I guess I'm trying to say that anytime you added un-needed connections to a particular system you are just asking for longer term troubles and an overall reduction in reliability. Keep It Simple! Most of today's major components come out of the panels so easily that I can't see a huge benefit of just adding connectors in case someday you might want to yank the whole panel out?
The point is you should wire and build your airplane for the 99th percentile of it's functionality and reliability, not the 1% "whatifs". I don't know if this all makes sense or not, but if it were me (and it is dozens of times we discuss panels with customers), I really try to put function ahead of form and convince people to do what makes sense from a functional, reliable and simplicity standpoint. You can't beat it!
Cheers,
Stein.
[quote] --
Jim Baker
Posted: Mon Oct 02, 2006 5:57 pm Post subject: Connectors vs. Straight Wire |
| Quote: | I guess I'm trying to say that anytime you added un-needed connections to a particular system
____________________________________________
Spot on! Besides, you'll have a lot of the panel terminated in
connectors of one sort or another anyway....how hard to remove
those.....
Tho I kinda wish the D-sub folks would go back to the old
Centronics wire bail form of shell attachment. No trying to get
the screw driver on the screw head in a spot you can't easily see.
Jim Baker
580.788.2779
Elmore City, OK
nuckollsr(at)cox.net Guest
Posted: Mon Oct 02, 2006 8:07 pm Post subject: Connectors vs. Straight Wire |
At 08:56 PM 10/2/2006 -0500, you wrote:
in reliability.
those.....
There ARE wire bails for keeping d-subs together. My favorite for
cable-to-cable d-subs is remove the jack-screw hardware and use
tye-wraps to keep them together.
Also, I'd ALWAYS use the machined d-sub pins. They're of the
same pedigree as the older and larger 'Cannon' plugs, etc.
I'm REALLY disappointed that folks who sell really expensive
avionics ship those sheet-metal, b-crimp pins with their
radios.
< with experiment. >
< --Lawrence M. Krauss >
Jim Baker
Posted: Tue Oct 03, 2006 6:42 am Post subject: Connectors vs. Straight Wire |
| Quote: | There ARE wire bails for keeping d-subs together. My favorite for
Must be rarer than hens teeth....all I can find is the IDC D-sub
w/bail locks. Did find a bail lock kit...going price was $7 a pop
with one vendor down to $3. Your Ty Wraps look better all the
time.
Jim Baker
580.788.2779
Elmore City, OK
Posted: Tue Oct 03, 2006 9:28 am Post subject: Connectors vs. Straight Wire |
At 09:40 AM 10/3/2006 -0500, you wrote:
time.
Take a look at page 17 of:
http://www.aeroelectric.com/Mfgr_Data/Connectors/ITT_Cannon/dsub_accessories.pdf
The next greatest thing are Positronic's V series spring
loaded slide latches. See page 10 of:
http://www.connectpositronic.com/pdf/SubDAccess_C007RevB1.pdf
Dennis Johnson
Posted: Wed Oct 04, 2006 6:42 am Post subject: Connectors vs. Straight Wire |
Hi Stein,
Thanks so much for your very thoughtful reply to my question about the trade-offs between straight-wiring my instrument panel to the airframe wiring and the alternative of putting connectors in every wire so that I can remove the panel for service.
I think I'll take your advice and go with the straight-wire concept, without connectors in every wire. The airplane I'm building has better than average access to the panel in-place and most of the stuff in the panel are relatively easy to remove.
Thanks again,
Dennis Johnson
Posted: Wed Oct 04, 2006 7:36 am Post subject: Connectors vs. Straight Wire |
At 07:37 AM 10/4/2006 -0700, you wrote:
| Quote: | Hi Stein,
From a servicing perspective, consider making your
panel from "modules" of flat sheet, each removable
for servicing. Make wire bundles to each module
long enough to allow pulling the module out for access
while extending a bundle. When mounted for operation,
coil the bundles behind the panel and secure with
tye-wraps. If your bundles are not too populace, this
is a good way to maintain both serviceability =AND=
wire integrity.
