Guy Buchanan
Posted: Tue Oct 03, 2006 7:18 am Post subject: Buying a KitFox, How to get parts to do some modifications |
At 09:17 AM 10/2/2006, you wrote:
| Quote: | So, the question is, are there "kits" available to install the electric
trim or the dual brakes, and if so, where are they offered?
Rans, (and ACS,) sells a "kit" to install a manual trim on their S-12. I am
adapting that kit for a manual trim on my plane. It definitely requires
some engineering.
| Quote: | How hard is it to add the electric trim? The electric part is easy for
me (I'm an electrical engineer), but I don't know how hard it would be
to modify the elevator, etc.
Adding electric the "right" way:
1. Strip one half the elevator.
2. Fabricate trim tab.
3. Cut and weld elevator to fit tab.
4. Weld in a bracket or support for the servo.
5. Install and wire the servo. (You know how to do that.)
6. Attach the tab using piano hinge.
7. Check it all out to make sure it works. (I'd guess 10 degrees up and 40
degrees down, depending on size.)
8. Re-cover the elevator, including access for the servo and hardware.
9. Paint and trim.
Now you could do all of that externally, including a bubble for the servo,
but you'd still have attachment problems, particularly since the elevator
is made from very small tubing.
Guy
Deceased K-IV 1200
A glider pilot too. |
