n395v
Posted: Wed Oct 04, 2006 5:43 am Post subject: Pin extraction tool KMA 24 or PMA 7000 |
Anyone have any idea of the name or number for the honeywell pin extraction and insertion tool for the connectors on KMA 24 or PS eng PMA7000 audio panels and where I can get them??
_________________ Milt |
nuckollsr(at)cox.net Guest
Posted: Wed Oct 04, 2006 6:42 am Post subject: Pin extraction tool KMA 24 or PMA 7000 |
At 06:43 AM 10/4/2006 -0700, you wrote:
Do the connectors have any numbers or brand names on
them? It's seldom possible to identify tools specific
to connectors based on the brand of product that uses
the connector. If you can see any identifying clues as
to the manufacturer of the connector, then we can access catalogs
for those devices and identify descriptions and sources
for the tools.
If you have a digital camera, take some closeups of
the connector body and email them to me. Perhaps I can
identify the connector by seeing its design.
< with experiment. >
< --Lawrence M. Krauss >
james(at)berkut13.com Guest
Posted: Wed Oct 04, 2006 8:06 am Post subject: Pin extraction tool KMA 24 or PMA 7000 |
Without knowing exactly what kind of socket/pin combination you have, it's
impossible to know for sure. However, I but it uses the same card-edge
Molex KK pins/connectors that most other King radio equipment uses.
If so, this will help you out:
http://www.berkut13.com/extractor.htm
James Redmon
Berkut #013 N97TX
n395v
Posted: Wed Oct 04, 2006 10:23 am Post subject: Re: Pin extraction tool KMA 24 or PMA 7000 |
| james(at)berkut13.com wrote: | Without knowing exactly what kind of socket/pin combination you have, it's
James,
Thats exactly the connector and the exact solution I needed, It worked like a charm.
Thank you
stein(at)steinair.com Guest
Posted: Wed Oct 04, 2006 10:25 am Post subject: Pin extraction tool KMA 24 or PMA 7000 |
They are standard molex/narco/king/pse square molex type pins. Instead of
spending $40-60 on the "official" pin tool...do the following
Flatten the end of a piece of .040" safety wire...works great.
Use a "bobby pin"
Use a flattened paper clip
or - what we use in my shop. Take an old piece of a hacksaw blade, take it
to be belt sander and sand a nice small flat "finger" into the end of it
about .040" wide. Works great and rarely breaks, and doesn't cost anything!
Any of the above solutions will work great.
Cheers,
Stein.
[quote]--
n395v
Posted: Wed Oct 04, 2006 12:29 pm Post subject: Re: Pin extraction tool KMA 24 or PMA 7000 |
I'd like to take this opportunity to put in a plug for Steinair.
Throughout my project he and all of his employees have been immensly helpful in answering questions, giving advice, expediting parts, and finding sources in order to help me complete my panel. I am sure they consumed many valuable hours out of their busy schedules to help.
This is one top notch group of people.
Posted: Wed Oct 04, 2006 3:24 pm Post subject: Pin extraction tool KMA 24 or PMA 7000 |
At 01:23 PM 10/4/2006 -0500, you wrote:
Use a "bobby pin"
Aha! THAT kind of tool. I've got a bunch of them, none
are purchased. See:
http://www.aeroelectric.com/Pictures/Tools/extraction_tool.jpg
. . . any dimestore pocket screwdriver can be dressed
down with your sander, grinder, etc to provide the proper
tab dimensions for unlocking this style of pin.
n395v
Posted: Wed Oct 04, 2006 5:33 pm Post subject: Re: Pin extraction tool KMA 24 or PMA 7000 |
Thanks bob
