nuckollsr(at)cox.net Guest
Posted: Tue Oct 03, 2006 9:11 am Post subject: Relays 'G's" skunk stink (CORRECTION) |
At 09:48 AM 10/3/2006 -0500, you wrote:
I'll take a stab. Mounting "cap down" means that gravity (and a bit of
engine vibration) will separate the main current contacts after the coil
is de-energized should the internal compression spring fail. Mounting the
other way would have the contacts potentially closing due gravity if the
spring failed with potential for all sorts of unhappy results.
Okay, gravity is a player here (my earlier post spoke of
g-forces which should have been qualified further to
aerodynamic g-forces). Suppose we hypothesize that the
spring is not going to fail. Now how does orientation
affect operation?
< with experiment. >
< --Lawrence M. Krauss >
wjoke(at)shaw.ca Guest
Posted: Tue Oct 03, 2006 11:38 am Post subject: Relays 'G's" skunk stink (CORRECTION) |
Well, "cap down" means that gravity (in the usual aerodynamic sense of
positive G maneuvering loads) will assist the internal spring in
separating the high current contacts when the coil energizing current is
removed. This would help in opening sticking contacts due to dirt,
deteriorated contact surfaces, and the like.
Jim Oke
Wpg., MB
<nuckollsr(at)cox.net>
> of engine vibration) will separate the main current contacts after
> the coil is de-energized should the internal compression spring fail.
> Mounting the other way would have the contacts potentially closing
> due gravity if the spring failed with potential for all sorts of
> unhappy results.
affect operation?
raymondj(at)frontiernet.n Guest
Posted: Tue Oct 03, 2006 2:52 pm Post subject: Relays 'G's" skunk stink (CORRECTION) |
Mr. Nuckolls,
I am disappointed and saddened to see you engaging in the "I've got a
secret" style of information dissemination.
If it is in the archive, please say so.
If you have the answer, please give it.
Cordially,
Raymond Julian
