n395v
Posted: Tue Oct 03, 2006 1:53 pm Post subject: Pull to low |
Is the term "pull to low" synonomous with connect to ground?
_________________ Milt |
mprather(at)spro.net Guest
Posted: Tue Oct 03, 2006 3:23 pm Post subject: Pull to low |
That's probably a safe way to interpret that direction..
As a point of note, there are several different specification standards
for the digital electrical signaling that is used to make one device
communicate with another. Some examples are TTL, LVTTL, SSTL.. Each one
may have a somewhat different definition for what voltage level is
required on an input for the device to interpret the signal as a logic
"low" (or zero). For many (most) applications, grounding an input will be
interpreted as a logic low signal. Some interfaces allow an input to
float up to 600mV (or higher) and still be interpreted as a low.
Hope that helps..
Matt-
n395v
Posted: Wed Oct 04, 2006 4:35 am Post subject: Re: Pull to low |
ThanksMatt
