Dennis.Kirby(at)kirtland. Guest
Posted: Wed Oct 04, 2006 11:56 am Post subject: rectifying problems maybe (UNCLASSIFIED) |
Classification: UNCLASSIFIED
Caveats: NONE
<< Have been holding right rudder...just a bit... to keep it straight.
The huge rudder trim tab, bent about 15 or so degrees to right as you
face the cockpit. jsf >>
John -
| Quote: | From your post, and after looking at the picture you attached, it
appears your trim tab is bent the WRONG way!
If you need to apply right rudder to keep the airplane in trim, then a
trim tab bent to the LEFT is what you want. This causes the free stream
air to deflect your rudder to the right, thus alleviating your need to
hold right rudder.
Dennis Kirby, yer neighbor to the north, in
Cedar Crest, NM
Caveats: NONE
