Drill bits
craigtxtx(at)yahoo.com
PostPosted: Sun Oct 08, 2006 1:37 pm    Post subject: Drill bits Reply with quote
I just ran through about a half dozen drill bits drilling the cotter pin holes in one wheel axle of my RV8A. That is some tough steel! Does anyone have a suggestion on what kind of drill bits to use here? There has got to be something tougher than the "titanium" bits I got at Lowes.
Craig Gallenbach
RV8A ...... trying to get it on the gear
rocketbob(at)gmail.com
PostPosted: Sun Oct 08, 2006 4:29 pm    Post subject: Drill bits Reply with quote
Craig, you're going thru bits because you are work hardening the steel. Turn the bit slow and put pressure on the drill. Under no circumstance do you want the drill to spin without a spiral chip coming out of the hole. Using an air drill is a no-no to drill through any kind of steel unless you have a teasing trigger and good torque at low speed. Also use some cutting oil like TapMagic, or a light aerosol oil like 3in1 if you don't have access to good cutting oil. You should be able to drill hundreds of holes in steel with one drill bit.
For drilling the cotter pin holes in the axles I recommend you use a long drill bit and a cordless drill.
FWIW the drill bits you can get at the home improvement places are generally inferior to HSS drill bits you can pick up at your local machine shop supply house. Almost always the USA-made bits are superior in quality.
Bob Japundza
RV-6 flying F1 under const.
On 10/8/06, Craig <craigtxtx(at)yahoo.com (craigtxtx(at)yahoo.com)> wrote: [quote]I just ran through about a half dozen drill bits drilling the cotter pin holes in one wheel axle of my RV8A. That is some tough steel! Does anyone have a suggestion on what kind of drill bits to use here? There has got to be something tougher than the "titanium" bits I got at Lowes.
Craig Gallenbach
[quote][b] http://www.matronics.com/Navigator?RV-List http://forums.matronics.com http://wiki.matronics.com [b]
chaztuna(at)adelphia.net
PostPosted: Sun Oct 08, 2006 6:14 pm    Post subject: Drill bits Reply with quote
Craig,
Buy Cobalt drill bits. Make sure they are Made In America. You can find these at machinist supply stores like MSC or McMaster-Carr. Your local Snap On, Mac and Matco Tool salesman also stocks them. These bits will drill through a grade 8 bolt.
Charlie Kuss
Craig Gallenbach
Email Forum -
- NEW MATRONICS WEB FORUMS -
- NEW MATRONICS LIST WIKI -
- List Contribution Web Site -
[/b]
dburton(at)nwlink.com
PostPosted: Sun Oct 08, 2006 7:51 pm    Post subject: Drill bits Reply with quote
Craig Gallenbach
Well, Lowes is not the place to buy drill bits…
High speed steel from a source like the ones Charley suggested will be OK. Avery or Cleveland also sells good drill bits
I’d also suggest learning how to sharpen a drill bit. It only takes a few seconds. I’m working out of the same drill bit set I purchased in the late 60s. I admit that I purchase bags of #30 etc because they are cheap and I want them sharp and true. The smaller the drill bit the more fussy they can be to sharpen.
It’s important to use the correct cutting fluid to drill aluminum or steel. Obviously we don’t use cutting fluid when drilling skins. Thicker parts require cutting fluid to keep from damaging your bit. The pressure and temperature the cutting edge of your bit experiences is great. Cutting fluid and not just any oil you have handy will make a huge difference.
Good luck,
Dave
[quote] [b]
PostPosted: Mon Oct 09, 2006 4:41 am    Post subject: Drill bits Reply with quote
Listers,
Thanks for the feedback on drilling hardened steel. Lessons learned:
  • Use cobalt bits. (actually, I started with them but I thought another type might work better and resorted to the Lowes "titanium" bits ..... bad choice)
  • Drill slowly. I was using an air drill and going much too fast.
  • Lubricate. I was using some of my air tool oil, but this was not very good at such high drill speeds.
Thanks for your help.
Craig
Oldsfolks(at)aol.com
PostPosted: Mon Oct 09, 2006 7:28 am    Post subject: Drill Bits Reply with quote
Craig;
At your NAPA store get "Rapid Tap" cutting fluid. It comes in a small can like 3 in 1 oil. Get one can for steel and another for aluminum.
The Cobalt drill, low speed and Rapid Tap should get the job done.
For drilling and tapping inside aluminum tube you need the Rapid Tap for aluminum.
Bob Olds
two time builder RV-4
Charleston,Arkansas
PostPosted: Mon Oct 09, 2006 7:34 am    Post subject: Drill bits Reply with quote
Craig Gallenbach
Well, Lowes is not the place to buy drill bits.
I'd also suggest learning how to sharpen a drill bit. It only takes a few
seconds. I'm working out of the same drill bit set I purchased in the late
be to sharpen.
It's important to use the correct cutting fluid to drill aluminum or steel.
Obviously we don't use cutting fluid when drilling skins. Thicker parts
Good luck,
Dave
Craig,
Both Bob J and Dave offer good advice. I also sharpen bits above 3/16" diameter. Small bits are hard to sharpen (hey, I'm over 50, my eyes aren't the greatest anymore) small bits. Small #30 and #40 Cobolt bits cost twice what quality HHS (high speed steel) bits do. However, I find that they last 5 times longer when drilling 2024-T3 aluminum. Be cheap, buy quality!
Charlie Kuss
Bruce(at)glasair.org
PostPosted: Mon Oct 09, 2006 7:49 am    Post subject: Drill bits Reply with quote
The best investment I made was high quality drill bits and a Drill Doctor to
sharpen them.
Bruce
www.glasair.org
PostPosted: Mon Oct 09, 2006 8:12 am    Post subject: Drill bits Reply with quote
---- Craig <craigtxtx(at)yahoo.com> wrote:
Listers,
Craig
Craig,
TIN (titanium) drill bits are only coated with Titanium, so they are not that great. The purpose of cutting oil is to cool the drill bit, not the lubricate. Cutting oils generally have a high sulfur content. Air drills are a no no for drilling steel.
Charlie Kuss
