Alfred Buess
Posted: Sun Oct 08, 2006 11:39 am Post subject: AW: automatic electric trim switch |
Mickey,
I use the Matronics Governor - http://www.matronics.com/governor/index.htm -
it has the additional advantage of speed regulation of your trim servo.
Greetings from Zollikofen and best wishes,
Alfred
Alfred Buess
Europa XS #097, Monowheel, Foam shortwing, Rotax 912S, Airmaster 332 CS
-----Ursprüngliche Nachricht-----
Von: owner-aeroelectric-list-server(at)matronics.com
[mailto:owner-aeroelectric-list-server(at)matronics.com] Im Auftrag von Mickey
Coggins
Gesendet: Sonntag, 8. Oktober 2006 15:35
An: aeroelectric-list(at)matronics.com
Betreff: automatic electric trim switch
--> <mick-matronics(at)rv8.ch>
Hi,
I'm installing a trio avionics altitude hold, and it has a cool feature
where it will trim the aircraft for you when it is on. They recommend a
radio shack bridge rectifier (part number 276-1183) and a DPDT relay
(275-206) to allow the normal trim to work even when the altitude hold is
engaged.
I vaguely recall someone selling a little kit with a the stuff needed so
that the pilot and co-pilot can use the trim without having to switch
manually. I assume this must be the same thing. Anyone have any links
to this product? I'd like to see if it either has better packaging or
other features that might be useful.
Mickey
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
rv8ch
Posted: Sun Oct 08, 2006 7:47 pm Post subject: AW: automatic electric trim switch |
Europa (Alfred Buess) wrote:
Thanks for the pointers! I also found one on this site:
http://www.strongpitchtrim.com/
With the rocketboy trim, I now have three to chose from. Most excellent!
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
_________________ Mickey Coggins
http://www.rv8.ch/ |
Bret Smith
Joined: 09 Jan 2006 Posts: 178 Location: Mineral Bluff, GA
Posted: Mon Oct 09, 2006 4:42 am Post subject: AW: automatic electric trim switch |
It would be really cool if there could be a side-by-side comparison test
with all three solutions. Particularly the functions, strengths and
weaknesses of each product.
Bret
_________________ Bret Smith
RV-9A (Emp) |
