		elli1409(at)bellsouth.net Guest
				 Posted: Thu Oct 12, 2006 10:53 am    Post subject: IO-240 |
				I am also interested in learning more about this  engine, since I will be installing it on my Rans S-16 in another year or so. I  will tell you what I have learned, with the caution that I am not expert,  just passing along my impressions:
  1-Be careful with Warp Drive props with this  engine. The Rans prototype S-16 experienced delamination problems with Warp  Drive. Nothing wrong with the prop, per se, but apparently the power pulses of  this engine were causing too much forward/backward stress on the blades. Rans  switched to a Sensenich wood prop, which is more flexible in this regime, and  the problem subsided. The S-16 is a 150-160 mph cruise airplane with this  engine. May not be a problem with other type a/c. Check with prop folks for  more/better information.
  2-Some parts for the engine are reportedly more  expensive than similar parts on other similar size engines.  Could be  because of low production, compared to O-200, O-235, etc. I also understand the  cylinders and other parts are taken from the IO-360 (Continental) design. Again,  a somewhat low-production engine. Can anyone verify this?
  3-I am looking into the Mattituck non-certified  version. Still expensive at about $19,000 vs. 24K for the certified version. Any  other sources out there?
  4-Not very many used IO-240's on the market. The  only production aircraft using it that I know of are the Katana and the Liberty.  Any others?
  5-There is a reported hard-starting problem with  the IO-240, which is rectified by installing either single or dual LightSpeed  Engineering electronic ignition module(s). Any experience here?
  Good luck with your Kitfox. Again, my information  is limited and may not be accurate. If anyone can add to it or correct it, I  would be very appreciative.
  S-16 Builder
  |  | - The Matronics Continental-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		donmorrisey(at)hotmail.co Guest
				 Posted: Thu Oct 12, 2006 11:26 am    Post subject: IO-240 |
				I looked into this engine as well for my BushCaddy R-120 (135 mph never exceed).  I ended up opting for a Lycoming O-235, primarily because the engine builder I had selected had only done a half dozen of the IO-240's and I can more than likely get my 110 mph cruise with the lower hp O-235.
   He indicated parts were somewhat hard to find and elli1409's email sort of reiterates this.  My understanding is that the IO-240 is a good, reliable engine.  I would definitely order through Mattituck as they have made lots of them and probably have a good availability of parts.
   	  | Quote: | 	 		    From: elli1409(at)bellsouth.net
 To: continental-list(at)matronics.com
 Subject: IO-240
 Date: Thu, 12 Oct 2006 13:53:05 -0500
  S-16 Builder
 st" target=_blank>http://www.matronics.com/Navigator?Continental-List
 p://forums.matronics.com
 //wiki.matronics.com
  | 	  All-in-one security and maintenance for your PC.  Get a free 90-day trial! Learn more!  [quote][b]
		FlyboyTR
  Joined: 04 Nov 2006 Posts: 215 Location: Mobile, Alabama
				 Posted: Mon Nov 13, 2006 1:23 pm    Post subject: Re: IO-240 |
				I have a Kitfox (Skystar) Vixen Series 5 with the Continental I0-240.  The engine was new and now has 275 hours.  The prop is a Warp Drive 70" 3 blade.  This past weekend I found cracks on two of the prop collars--close to the hub.  Spoke with Warp and was told they would not cover the prop because of the "sharp impulse" the engine has.  I've ordered an Ivo 2 blade Magnum in-flight adjustable.
 I've had no starting problems with the engine.  Just the usual hot start issues because of the fuel injection.
  _________________ Travis Rayner
Mobile, AL
Skystar Vixen, N-789DF
Continental IO-240,  Prince P-Tip Prop
ADI-II Autopilot
AnyWhereMap Navigation with weather
www.enotam.net (My Flying Info Website) |
