MauleDriver(at)nc.rr.com Guest
Posted: Tue Oct 10, 2006 7:14 am Post subject: Electric Aileron Trim |
I'm getting ready to order my Fuse and Wing kit. Are any of you
installing Van's electric trim? What are your thoughts on it?
Given Van's bias towards 'less', I'm guessing there is a good reason for
making the trim option available.
Rick S.
Vern(at)teclabsinc.com Guest
Posted: Tue Oct 10, 2006 8:06 am Post subject: Electric Aileron Trim |
Hi Maule,
I am installing the aileron trim and this came after conversations with
both Trutrak and Van's. The reason for it is as fuel is burned off of
one tank the wing gets lighter. If you are using an autopilot this will
compensate for this condition until you turn the auto pilot off and then
the heavier wing will tend to drop.
How much of a problem this is I don't know. The Mooney I used to fly had
an auto wing leveler that was basically always on. In addition to this
we switched tank every 1/2 hour so the weight difference between the
wings was only 30 lbs. max. It would be interesting to get feedback from
those flying, as to what they have notice in trim from fuel burn.
Vern (40324)
flysrv10(at)gmail.com Guest
Posted: Tue Oct 10, 2006 10:59 am Post subject: Electric Aileron Trim |
I have the aileron trim and I find it necessary for fuel and passanger imbalance. I do not seem to need any adjustment if Trutrak is engaged.
Rob Kermanj
On Oct 10, 2006, at 12:05 PM, Vern W. Smith wrote:
[quote]--> RV10-List message posted by: "Vern W. Smith" <Vern(at)teclabsinc.com (Vern(at)teclabsinc.com)>
Hi Maule,
Vern (40324)
coop85(at)bellsouth.net Guest
Posted: Tue Oct 10, 2006 1:22 pm Post subject: Electric Aileron Trim |
I'm probably a minority, but I opted not to get the aileron trim "yet" for
budget reasons. I have about 60 hours on the airplane and it really hasn't
been an issue. I can tell if I've fed from one tank too long as it takes a
little side pressure, but that goes away fairly quickly after switching
tanks and is non-existent if I switch after level off and then every 30
minutes on schedule. Of course the Tru-trak makes quick work of the whole
issue.
My thoughts, it would be nice to have, but not a show stopper by any means
and you could always add it later if required. Of course it's always easier
to put something like that in while in the building process rather than wait
until later.
Marcus
Tim(at)MyRV10.com Guest
Posted: Tue Oct 10, 2006 7:51 pm Post subject: Electric Aileron Trim |
Have you spent much time with 4 seats full yet? I find the
aileron trim a must depending on who's filling my seats
and how we pack them in. there are times i wouldn't want
to be without it, and times when I have no need for it.
But, I would recommend it to everyone as worthwhile.
hasn't
a
issue.
easier
wait
until later.
Marcus
Posted: Wed Oct 11, 2006 2:53 am Post subject: Electric Aileron Trim |
I've had several flights with 4 folks of different sizes with no significant
impact. Maybe I've just been lucky so far.
I would certainly not avoid having aileron trim, my thoughts were that's it
just not an absolute "must have".
Marcus
Posted: Wed Oct 11, 2006 3:55 am Post subject: Electric Aileron Trim |
I would agree. Not a Must have, but I've found it useful.
I suppose I could say the same for rudder trim.... I don't have
that yet, but I'd certainly be adding it if I hadn't painted yet.
I will probably add it in the winter season.
I flew 975 miles yesterday to Albuquerque from Wisconsin and
found w/o rudder trim There wee times My fuel gauges read improperly.
Going to LOE, on Friday and sat.
for you Vegas dudes, I'll Probably be coming there tonight. Going
to VGT. Not any time for much visiting.... have
the kids. Today is the Canyon and tomorrow more sights to see.
feel free to find the plane though. I'll have my cell.
significant
it
Marcus
wayne.e(at)grandecom.net Guest
Posted: Thu Oct 12, 2006 10:02 am Post subject: Electric Aileron Trim |
I wasn't aware there was a rudder trim available. Where does one go to find it?
Wayne Edgerton #40336
jesse(at)itecusa.org Guest
Posted: Thu Oct 12, 2006 11:14 am Post subject: Electric Aileron Trim |
We use Aerotrim, (305) 864-3336. It doesn’t look like much, but works great. We get it without the indicator, just the servo, and pay just under $200, I think.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton
Sent: Thursday, October 12, 2006 8:06 AM
Subject: Re: Electric Aileron Trim
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234567890123
-- Date: 10/11/2006
10/11/2006
