armywrights(at)adelphia.n Guest
Posted: Wed Oct 11, 2006 2:44 pm Post subject: QB Floor Pans and Snap Bushing source |
I finally bit the bullet and did it right (IMHO). I took my Columbus Day and removed the gear brackets, fwd floor pans (only a few rivets in each to hold them) and the covers for the control sticks that screws to the front of the seat area. Then I vacuumed, cleaned, primed the areas, laid the Super SoundProofing with Sticky Stuff, and then reinstalled everything. Total time spent was all day, 12 hours. Hardest part was getting the bolts out of the holes that go through the spar areas. There’s not a whole lot of room for fingers and tools, so you just have to work at it. Backing the bolts out was VERY tedious. I took a few pics and will try to post some.
Oh, another thing. If you are shorted a few snap bushings and don’t want to have to pay Van’s or someone else shipping on some $.07 bushings, do what I did – on the bushing itself is the name of the company, HEYCO, in Tom’s River, NJ. After realizing that my local supplier didn’t carry them and the minimum order was in the 1000’s of parts, I went to the website, www.heyco.com. Heyco has a sampling service where you can type in the part number that you need (up to 6 I think) and tell them how many you would like to sample. Not to be greedy, I asked for 6 of two different sizes and they arrived in the mail today. I also asked for a catalog to check their other goodies….
Rob Wright
#392
Fuse
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron
Sent: Thursday, October 05, 2006 8:34 PM
Subject: RE: QB Floor Pans
I have the slow build fuse and found mounting the gear legs a pain in the butt. I can see how the guys in the Phillipines are buggering them up. The other area that a lot of people have trouble with is around the F-1001B and WD-1002 weldment at the fwd fuse (not enough hole edge clearance). I wonder how the QBs look in that area??
cheers,
Ron
168
-----Original Message-----
[mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)]On Behalf Of Chris , Susie
Darcy
Sent: Friday, 6 October 2006 10:52 AM
Subject: Re: QB Floor Pans
--> RV10-List message posted by: "Chris , Susie Darcy" <VHMUM(at)bigpond.com>
You need to remove the gear mounts and check all the bolt holes that hold
them in as all the side holes on mine were F%$#(at) up so I had to enlarge and
put bigger bolts in. Other QB builders have reported this! Its usualy the R
side only.
So worth tacking out just for that.
Chris 388
toaster73(at)earthlink.ne Guest
Posted: Wed Oct 11, 2006 3:24 pm Post subject: QB Floor Pans and Snap Bushing source |
So as soon as Heyco sees all these hits for samples from RV-10 types...the party is over!
-Chris
#40072
retiredpilot03-serv(at)ya Guest
Posted: Thu Oct 12, 2006 5:59 am Post subject: QB Floor Pans and Snap Bushing source |
Hey Rob,
I have just done the same thing and agree with you completely about the bolts, very difficult! I have a question for you: The forward brace of the LG bracket shows fastening to the floor by 2 AN3-5A bolts but the picture and description gives no clue as to what and how you fasten it (see P. 29-21). I have gone through the plan book and can find no reference or even instructions for drilling. Any help would be appreciated. Thanks
Robert Vinroot
40343
Rob Wright <armywrights(at)adelphia.net> wrote:[quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]-->RE: QB Floor Pans st1\:*{behavior:url(#default#ieooui) } <![endif]--> I finally bit the bullet and did it right (IMHO). I took my Columbus Day and removed the gear brackets, fwd floor pans (only a few rivets in each to hold them) and the covers for the control sticks that screws to the front of the seat area. Then I vacuumed, cleaned, primed the areas, laid the Super SoundProofing with Sticky Stuff, and then reinstalled everything. Total time spent was all day, 12 hours. Hardest part was getting the bolts out of the holes that go through the spar areas. There’s not a whole lot of room for fingers and tools, so you just have to work at it. Backing the bolts out was VERY tedious. I took a few pics and will try to post some.
Rob Wright
#392
Fuse
cheers,
Ron
168
millstees(at)ameritech.ne Guest
Posted: Thu Oct 12, 2006 7:22 am Post subject: QB Floor Pans and Snap Bushing source |
Robert:
See page 28-18. I just did mine, and it worked out fine.
Steve Mills, RV-10 40486
finishing fuselage
Naperville, Illinois
Posted: Fri Oct 13, 2006 5:56 pm Post subject: QB Floor Pans and Snap Bushing source |
A lot of this stuff is hard to find in the plans until you’ve gone through them at least 48.2 times!
28-17 Figure 1 shows drilling through the LG bracket, 28-18 figure 1 shows installing nutplates and enlarging holes for AN-3 bolts.
Rob Wright
#392
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robert
Sent: Thursday, October 12, 2006 8:59 AM
Subject: RE: QB Floor Pans and Snap Bushing source
Hey Rob,
Robert Vinroot
40343
Rob Wright
#392
Fuse
cheers,
Ron
168
