rparigor(at)SUFFOLK.LIB.N Guest
Posted: Tue Jan 24, 2006 10:04 pm Post subject: Rotax 914, run fuel pump with no battery? |
Studying Rotax 914 schematic, the main fuel pump is wired to the B+ of the
regulator.
It appears if you open the alternator output switch, they expect the
alternator could run the fuel pump with no battery in circuit???
They do have a 22000mF capacitor from B+ to ground.
OK another question comes to mind. On Bobs Z-8 which uses a SD-8, if the
output relay was opened (not connected to battery or Buss) and you
connected a 3 amp fuel pump motor to the red output of the regulator would
it run and be happy for an emergency?
Called for on Z-8 is a 20000 to 50000mF capacitor connected to red output.
Thx.
Ron Parigoris
