kearney(at)shaw.ca Guest
Posted: Fri Oct 13, 2006 6:58 pm Post subject: Question for the tool mavens |
Hi
Over the past few days I have been assembling all the miscellaneous power tools that I need to start construction. One in particular has me a bit perplexed.
I just bought a Ryobi 9” band saw that came with a wood blade. I put a new ¼” x 14 tooth / inch blade in. The blade specs say it is ok for non ferrous materials at a reduced speed. Unfortunately this band saw does not have a speed adjustment. It is rated to cut a constant speed of 3000 fpm.
I have tried cutting a test piece of 2024 and it seems ok but I am out of my depth as to what is acceptable and safe.
My question is, show I find a variable speed band saw or will this one do. Opinions?
Inquiring minds need to know.
Les Kearney
RV10 #643 – Inventorying a plethora of bags containing wee tiny tail kit parts
jdalton77(at)comcast.net Guest
Posted: Fri Oct 13, 2006 7:17 pm Post subject: Question for the tool mavens |
Les,
I have the same one and it works fine. I did by the largest metal blade I could though - I found the 1/8" in blade flexed too much.
Other than that it's fine.
Jeff
Posted: Fri Oct 13, 2006 7:54 pm Post subject: Question for the tool mavens |
Jeff
Thanks for the info. I will stay with what I have.
Cheers
Les
