Posted: Sun Oct 15, 2006 1:10 pm Post subject: Firestar/Warp Drive Noise/Tuning The Two Stroke |
| restore the stock jets and go strictly by your plug color to
| determine any further adjustments if necessary.
| Gene
Gene:
Before the days of readily available and less expensive
EGT/Pyrometers, We always used plug readings to dial in two and four
strokes.
What procedure do you use in dialing in a two stroke using spark plug
readings?
Take care,
_________________ John Hauck
Titus, Alabama |
