		jdalton77(at)comcast.net Guest
				 Posted: Mon Oct 16, 2006 7:21 pm    Post subject: Elevator skin repair suggestions |
				While removing the AN-3 bolts for the umteenth time that connect the elevators to the HS I slipped with the wrench and made a small tear in the skin of the elevator.  It's about 1" long.
  I would like to repair it, rather than replace the entire skin.  I thought I'd clean it up at epoxy a small square of aluminum to the underside of the tear and fill in the rest with filler.  It's is not visible when the the elevator is in the trailing position.
  Thoughts?
  Jeff
		fehdxl(at)gmail.com Guest
				 Posted: Mon Oct 16, 2006 9:22 pm    Post subject: Elevator skin repair suggestions |
				Jeff, I would make the tear a square hole, then fabricate a small piece to exactly fill the hole, as well as a larger piece which would rivet to the existing skin as well as create the lip for the smaller piece to rivet to.  Think of those repair kits used to fix a large hole in drywall.  AC 43-13 has all kinds of good information about this regarding edge spacing, minimum number of rivets per square inch, etc, etc.  Of course, if the tear is very close to the edge, on a curved part of the HS, or near a rib, the solutions become more complex.  Hope this helps.  -Jim
  On 10/16/06, jdalton77(at)comcast.net (jdalton77(at)comcast.net) <jdalton77(at)comcast.net (jdalton77(at)comcast.net)> wrote:   	  | Quote: | 	 		    While removing the AN-3 bolts for the umteenth time that connect the elevators to the HS I slipped with the wrench and made a small tear in the skin of the elevator.  It's about 1" long.
  Thoughts?
  Jeff
 o=\o   [quote][b]
				 Posted: Tue Oct 17, 2006 5:22 am    Post subject: Elevator skin repair suggestions |
				Thanks Jim,
  Good advice.  The tear is both by the edge and  on a curve, but I think I can make it work.  Thanks.
  Jeff
  [quote]   ---
		apilot2(at)gmail.com Guest
				 Posted: Tue Oct 17, 2006 6:01 am    Post subject: Elevator skin repair suggestions |
				Give serious thought to reskinning that area. Elevator is a balanced
 control surface. So either you will have a small difference in counter
 weight on that side if you add metal for a patch, or not. The skin
 isn't that expensive, it is mostly the time involved. I tend to think
 you will be happier in the long run with fresh skin, but that is your
 decision.
 On 10/17/06, jdalton77 <jdalton77(at)comcast.net> wrote:
  Thanks Jim,
  Jeff
				 Posted: Tue Oct 17, 2006 6:09 am    Post subject: Elevator skin repair suggestions |
				Do you think a 2" square piece of .32 aluminum will affect elevator balance?
 I could always add this extra weight to the other side (can you even weigh
 something that small?)
 I would consider changing the skin if it were visible AND I wasn't almost
 completely assembled.
 Jeff
		Jack.Phillips(at)cardinal Guest
				 Posted: Tue Oct 17, 2006 6:31 am    Post subject: Elevator skin repair suggestions |
				If you choose to add any weight, be very careful when flight testing the
 airplane.  The reason for balancing the control surfaces is to control
 flutter.  There have been cases where the extra weight of adding paint
 to control surfaces caused them to flutter at high speeds.
 I would doubt that such a small piece of aluminum would cause the
 balance to change dramatically, but by the time you rivet it in place
 with a doubler to support it, you might add enough to cause a problem.
 Read Vaughn Askue's book "Flight Testing Homebuilt Aircraft" about how
 to conduct flutter testing.
 If it were me, I'd replace the skin before I would add weight to it.
 Jack Phillips
 #40610
 Working on the HS
		rvbuilder(at)sausen.net Guest
				 Posted: Tue Oct 17, 2006 8:02 am    Post subject: Elevator skin repair suggestions |
				Square patches indicate 90 degree corners and 90 degree  corners equals stress risers.  Try to avoid any sharp corners in that type  of repair.  I also agree with others that you might want to seriously  consider reskinning.  It will bug you until you do it anyway.
  Michael Sausen
  -10 #352 Should restart building Jan  1
    From: owner-rv10-list-server(at)matronics.com  [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim  Beyer
 Sent: Tuesday, October 17, 2006 12:20 AM
 To:  rv10-list(at)matronics.com
 Subject: Re: Elevator skin repair  suggestions
    Thoughts?
    Jeff
 o=\o [quote]
