Series 6 vs. Series 7 FWF...
n79rt(at)kilocharlie.us
PostPosted: Wed Jan 25, 2006 6:51 am    Post subject: Series 6 vs. Series 7 FWF... Reply with quote
Could some of you folks that know such things, point me to a couple of
representative pictures of the series 6 and 7 fwf installations? Trying
to see what is different...I found several FWF pictures on the
Sportflight site, but don't know what version I'm looking at.
Jeremy Casey
jdmcbean(at)cableone.net
PostPosted: Wed Jan 25, 2006 7:37 am    Post subject: Series 6 vs. Series 7 FWF... Reply with quote
Jeremy,
The differences are significant.. The Series 7 FWF reduces the installation
time by as much as 60%. The engine also moved forward about 5".
Have a Safe New Year !!
John & Debra McBean
www.sportplanellc.com
"The Sky is not the Limit... It's a Playground"
PostPosted: Thu Jan 26, 2006 3:39 pm    Post subject: Series 6 vs. Series 7 FWF... Reply with quote
Moving the motor 5" is a VERY SIGNIFICANT change!!! If the C.G. was
close to right before then something else had to move...(battery to the
tail?)
I understand the reasoning for more room behind the engine...the RANS S7
FWF is about 10 pounds of ____ in a 5 pound can...requires a left handed
midget who amputated his pinky and ring finger to get somethings in
there... (Remember the S7 uses the same motor on a firewall about 23"
wide Wink
Just trying to get educated in the ways of Kitfox...history of why
things were changed explains lots of stuff when your building a kit that
is 2 models old.
Jeremy Casey
aldaniels(at)fmtc.com
PostPosted: Thu Jan 26, 2006 5:02 pm    Post subject: Series 6 vs. Series 7 FWF... Reply with quote
I think the problem was that the 5,6 with the Rotax was not heavy enough
up front, and it limited how much you could put in the cargo area. The 5
inches made it a better balanced plane, but when I built my 5 with a 7
FWF which I made as light as I could and set the max. weight at 1320, I
decided that I would be better off to use 1 degree of forward wing
sweep. I also put an oversized elevator on for more slow speed
authority. I don't know how much the 1 degree helped as I could roll the
tail wheel before the mains on my standard 7 about as easy as I can with
my 57.
tail?)
wide Wink
is 2 models old.
Jeremy Casey
rjdaugh(at)rapidnet.com
PostPosted: Thu Jan 26, 2006 5:11 pm    Post subject: Series 6 vs. Series 7 FWF... Reply with quote
Jeremy,
I have the S-7 firewall forward on my Series 5. Moving the 912S ahead does
move the CG ahead. But that was the purpose! Because the engine is light,
this is needed to allow the full use of the 150 lb capacity of the baggage
area. My plane is light and I established a 16 lb tool kit (that I like to
have anyway) as required equipment. This keeps me in balance when solo with
minimum fuel.
Randy - Series 5/7 912S
PostPosted: Thu Jan 26, 2006 6:04 pm    Post subject: Series 6 vs. Series 7 FWF... Reply with quote
Alan...seems that forward sweep would aggravate an aft CG condition?
Did you mean rearward sweep?
PostPosted: Thu Jan 26, 2006 8:19 pm    Post subject: Series 6 vs. Series 7 FWF... Reply with quote
Forward wing sweep does move the center of lift forward and give a
different CG envelope. I did it as I do not intend to use the 150 pound
limit in the cargo compartment and wanted it better balanced for light
operations. Loaded very light without anything in the cargo compartment
puts you forward of or close to the forward limit. My wife can fly it
for fun alone and still get a good flair, or we can load it up and go
camping with a cargo limit of something like 120 pounds in the cargo
bay. I normally do not carry bricks or sacks of cement so that is not a
problem. Like I said, I am not sure it really did much. I can tell you
that when my wife flies the Kitfox, the plane is not the only fox flying.
bnn(at)nethere.com
PostPosted: Fri Jan 27, 2006 10:26 am    Post subject: Series 6 vs. Series 7 FWF... Reply with quote
At 08:18 PM 1/26/2006, you wrote:
I can tell you
Anyone who makes such a claim is required to supply photographic evidence
to substantiate it! Wink (Preferably the kind of evidence that leads to
teeth gnashing and shirt rending!)
Guy
larsonmil3(at)earthlink.n
PostPosted: Fri Jan 27, 2006 10:52 am    Post subject: Series 6 vs. Series 7 FWF... Reply with quote
The Fox in ??? here has had many marriage proposals.
So stand in line when she finally dumps the bum (Alan)
Mark Miller
PostPosted: Fri Jan 27, 2006 1:30 pm    Post subject: Series 6 vs. Series 7 FWF... Reply with quote
<snip>
Alan & Linda Daniels
flying.
<snip>
Clear on the wing sweep thing...as far as how many "foxes" are flying
you must be a lucky man...a good-looking wife WHO IS A PILOT too!!! (my
eyes are tearing up...I'm so jealous...my wife is a knock-out but I
couldn't get her in a plane at gun point Wink
Jeremy Casey
roncarolnikko(at)hotmail.
PostPosted: Fri Jan 27, 2006 3:16 pm    Post subject: Series 6 vs. Series 7 FWF... Reply with quote
I too have two foxes, but plan on sitting a blow up doll on a lawnchair in
front of the hanger.
Ron NB Or
Subject: RE: Series 6 vs. Series 7 FWF...
Date: Fri, 27 Jan 2006 16:28:53 -0500
<snip>
flying.
<snip>
Jeremy Casey
http://toolbar.msn.click-url.com/go/onm00200415ave/direct/01/
