Posted: Mon Oct 16, 2006 8:01 am Post subject: Prop Effency |
Richard
I changed the Subject
Prop efficiency is at least partly related to how fast the prop has to
accelerate the air it is moving to get thrust. A small prop has to
accelerate the air allot more to get its thrust and gets a smaller
percentage of the input power changed into thrust. A large prop moves more
air so it will need to accelerate the air less and gets more thrust for the
same power. Now a prop with more blades is less efficient than one with less
but is less pronounced than the, large verses small prop differences.
You are right that as you increase the volume of air that you move with a
prop for the same power the speed range that the prop produces thrust gets
smaller. At some point when increasing the prop area diameter, blade cord,
and number of blades you have to pitch for climb or cruise. The advantage of
a in flight adjustable prop is that doesn't have to stay at one setting it
can get more thrust in both climb and cruise.
I don't think that the high fuel consumption is a result of the additional
prop blade in this case unless he is cruising allot faster.
I base my claims on observations I have made on my airplane with two
identical engines one turning a two bladed 60 inch prop at 3200 RPM and the
other turning a three bladed 72 inch prop at 2000 RPM with a 1.61 to one
reduction. The thrust is almost double for the larger prop. The trade off is
that I have had to pitch for cruise. The up side is that I get more cruise
speed 75MPH vs 65MPH and much better climb in spite of lower climb engine
RPMs. My fuel consumption and the engine temps are a bit less with the
larger slower turning prop flying faster.
Last night in the cool 45 degree air I was able to keep my big VW cool at
higher power levels than I can normally sustain. I did some low level flying
like we have to do going into Oshkosh (well maybe a bit lower) but last
night the air was smooth and I was able to fly 85-90 MPH at 3600-3700RPM on
the engine. Popping up over woods and tree lines at these power levels and
speed is breathtaking. I suspect I was seeing power close to what you guys
with the 100HP Rotes get wow what a kick. I'm tempted to do some better
cooling work on the engine and maybe move the oil cooler to get more air
flow. Well maybe not, It keeps me from over stressing my engine???
Rick Neilsen
Redrive VW powered MKIIIc
Richard Pike
Posted: Mon Oct 16, 2006 10:16 am Post subject: Prop Effency |
I mostly agree with you but I think there are a couple factors involved.
Since you are using a VW and he & I a small displacement 2 stroke 582, you
have a huge torque advantage when it comes to turning a larger prop. And
from your post, it sounds like you have a great engine combination.
I was thinking about this whole deal a couple hours ago while out mowing the
airstrip, (last time this year!) and back before my current 582, I had a 532
on my MKIII. I had bought it from a guy in our EAA chapter who had it on a
Zenair CH701. Zenair has persuaded him to put a 72" two blade Ivo on that
poor 532, and while it certainly accelerated and took off quick, he was
always flying it around at 6,200 rpm and only about 60 mph, because in order
to get the engine to turn up, he had to take all the pitch out of it. And he
burned over 5 gph. It was like the ultimate climb prop, but that was it's
only useful function.
Now what if it had been an inflight adjustable prop? I think as soon as he
would have cranked in more pitch, the engine would simply have slowed down,
and the airplane would probably not have speeded up any, if at all, because
there is no way the engine could have pulled that much prop with any sort of
normal amount of pitch in it. Now obviously this is an extreme example, but
I think that is what happens when you put a 3 blade 68" prop on a 582, and
then attempt to compensate for too much prop by changing pitch, it is still
too much prop. You can't get the speed, but you do increase prop load, and
correspondingly high fuel burn.
When I owned that same 532, Ivo told me to use a 64" 3 blade prop, and it
was too much prop. As John and I bantered about yesterday, a 532 is very
pipey, and with the 3 blade 64" pitched to give any sort of decent cruise,
the 532 given half a chance, would fall off the pipe. The only way it worked
right was to have shallow pitch, and then I had to cruise at 5,800 rpm at
about 60 mph. I took away one blade and it worked great as a 2 blade 64"
Went to a 2 blade 66", and it still worked great. Sold the 532 and got a 582
and it works great with a 2 blade 68". Good acceleration & climb, good speed
spread, and low rpm cruise.
I am not any great aerodynamicist, (probably didn't even spell it right) but
between a lot of trial and error, and thinking about the results, this is
how I think it works. Obviously subject to change, correction and
instruction.
Richard Pike
MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Mon Oct 16, 2006 12:30 pm Post subject: Prop Effency |
Richard
I only know what I have experienced and what I have been told by people that
I think should know. I agree with you that a large prop depending on how
large will get you into a situation where it is a good climb prop or a good
cruise prop. I suppose you can get a prop the is just too large for
everything. I have prop with a cruise pitch setting. The redrive guys tell
me that I should see 3600-3800 in climb and 3200 in cruise I get a good
cruise speed (74MPH) at 3200 but I only get 3400 in climb(50MPH).
You indicated I have allot of torque in my engine and I do but it is the
reduction ratio that can make a low torque high RPM engine into a high
torque low RPM prop drive.
When I bought my prop Stuart at PowerFin said that the prop I have is the
perfect prop for a 582 on a Kolb. My prop is a F model three bladed 72 inch
PowerFin. This model prop has a wide cord so this is a big prop. I don't
remember what reduction ratio this would be the best prop for but Rotax does
sell some optional ratios for their engines that are in the 3-4 to one area
and this must be what he was talking about. There are just too many
variables in this area for most of us and to get the best of everything with
out allot of experimentation. The guys that make my redrive sell engine
packages for those Newport replicas and they swing a 8 foot prop so that
they look right. What they didn't expect was the large performance gains
they got. Again the Newport engines are using better than 3 to one
reduction ratio.
I still think the air adjustable prop would work just about perfect in
situations were you have a good climb prop but need more pitch for cruise.
They biggest problem I could see would be cranking in too much pitch. The
difference between climb and cruise pitch on Kolbs isn't much. From my
experimentation with my ground adjustable a small change can have a big
effect.
But what do I know?????
Rick Neilsen
Posted: Mon Oct 16, 2006 12:39 pm Post subject: Prop Effency |
cool at
level flying
last
3600-3700RPM on
levels and
you guys
better
air
| Rick Neilsen
Rick:
Shoot! Do some better cooling work and have fun with your VW powered
mkIII.
Welcome to what it is all about..........
Can you imagine flying coast to coast like that? Sometimes, it is the
only way to stay awake and enjoy the ride.
_________________ John Hauck
Titus, Alabama |
Posted: Mon Oct 16, 2006 1:14 pm Post subject: Prop Effency |
Richard:
Never had a problem with two blade wood, three blade wood, or three
blade Warp Drive props.
Prop them all the same way, WOT straight and level, bump the red line
for max continuous duty, which is 6,500 rpm for Rotax two strokes and
5,500 rpm for Rotax four strokes.
Still get the best combination of cruise and climb. Of course, my
cruise and climb ain't the same as your cruise and climb. Anything
over 80 is gravey. Anything less than 80 mph ground speed is
depressing.
The mkIII is an 85 mph cruise airplane. Anything over that and you
are wasting horses. 90 mph and you hit that invisible wall.
I sure have a lot of fun between take off roll and 90 mph though.
BTW Fuel burn for my 582 at 5,800 rpm and 80 mph was 5 to 5,5 gph.
Fuel burn on my 912UL at 5,000 rpm and 85 mph was 4 gph.
Fuel burn on my 912ULS at 5,000 rpm and 88 mph was 5 gph. Noticed I
said "was" because that engine is gone and I have not flown the new
912ULS. Maybe it will get better fuel burn.
As another added note, Jim Ballenger flew my old 912ULS on his MKIIIx.
He is one happy camper after pulling off the 582 which mysteriously
seized on takeoff on his last flight with that engine.
Take care,
Titus, Alabama |
pj.ladd(at)btinternet.com Guest
Posted: Tue Oct 17, 2006 10:23 am Post subject: Prop Effency |
Hi Richard,
<< where it is a good climb prop or a good cruise prop. >>
I guess if that were not so there would be no market for variable pitch
props??
By the way `Nieuport` not Newport please.
Incidentally, while speaking French, I found out on holiday that `denim`
which America has made more or less its own through jeans and other working
and fashion clothes etc was in fact invented in France. Theres a bummer.
It is actually `de Nimes` after the town of Nimes.
Can`t actually tell you anything about Nimes, even if you wanted to know as
the nearest I got was the `Pont du Gard` just outside the town. This is a
tremendous Roman Aquaduct across a valley. It is awe inspiring. Three rows
of arches on top of each other engineered to be just enough out of level
for the water to flow. Built 2000 years ago and looks good for another 2000.
If you haven`t come across it before look it up on google. Amazing. I have
been trying to visit it for 20 years. The wait was well worthwhile.
Incidentally in a town just beyond Nimes I found an advert in my hotel for a
`bapteme de l`air` in an ultralight on floats.Phone call to try and organise
this only to find that the guy had finished his season the day before. Great
shame as it was a super evening, no wind and a calm sea flat as a table
top. I couldn`t talk him into it though. French!!!!
Cheers
Pat
