Lynn Matteson
Posted: Wed Oct 18, 2006 3:42 pm Post subject: Kitfox/Jabiru trip numbers |
I just got back from a 275.5 statute-mile round trip, which took 2.9
hours. Included was a .4 hr. trip "around the patch" with a friend of
mine. Upon return, I filled the tanks to the rim, like I did just
before leaving. It took 9.5 US gallons. This worked out to 29 mpg, and
3.28 gallons/hour. All figures were via my GPS. I tried to hold to
90mph airspeed, and let the ground speed fall where it may. All speeds
were pretty close whenever I could glance at the gauges...I was pretty
busy flying the plane in the marginal weather....ok weather according
to the FSS. I wonder what weather channel they were watching?
Lynn
Kitfox IV Speedster...Jabiru 2200
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
dave
Posted: Thu Oct 19, 2006 4:40 am Post subject: Kitfox/Jabiru trip numbers |
Lynn, Congrats on your first x country.
Hopefully a few more soon. Do you have a cabin heater ?
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Lynn Matteson
Posted: Thu Oct 19, 2006 5:47 am Post subject: Kitfox/Jabiru trip numbers |
Well, it wasn't the first x-country, just the first since I cut the
flight training/flight examiner "umbilical cord", and the first
out-of-state trip. Yes, I've got two little 6" long heat muffs that
attach to the front exhaust pipes of the Jabiru engine. They seem to
work ok for the present outside temps, but I need to seal up some air
leaks into the cabin before they will be really enough.
Lynn
Dave
N369LM |
algate(at)attglobal.net Guest
Posted: Thu Oct 19, 2006 8:28 am Post subject: Kitfox/Jabiru trip numbers |
Lynn
Thanks for the info on the heat muff. You mentioned that you were going to
fit some baffles to slow the air down - have you thought about using
stranded Stainless steel (used for kitchen wash scrubbers) I used this on my
582 muffler heater muff and it worked great. It slows down the air and also
heats up itself adding more BTU's.
When you made your muff did you hinge it - if you can send me a Photo off
line that would be great.
Gary Algate
Classic 4 Jab 2200
Michel
Posted: Thu Oct 19, 2006 9:03 am Post subject: Kitfox/Jabiru trip numbers |
On Oct 19, 2006, at 6:32 PM, Algate wrote:
| Quote: | - have you thought about using stranded Stainless steel (used for
Amazing! This is EXACTLY what I did with my Jabiru, last winter, Gary!
I installed a cabin heater, from the muffler, but the air was coming in
too fast and it didn't had the time to warm up. After adding a SS
kitchen scrubber at the cabin's end of the hose, it comes in slower and
warmer.
.. great minds think alike!
Michel
_________________ Kitfox 3 - Jabiru 2200 |
Lynn Matteson
Posted: Thu Oct 19, 2006 9:42 am Post subject: Kitfox/Jabiru trip numbers |
Ooooh, that sounds like a great idea, Gary....photo(s) on the
way...Yes, I hinged it, although the hinge is more of a means of
securing the halves rather than a means of flexing the muff for
installation. What I mean is, I can't put the muff in place with the
two halves hinged together...it won't clear the obstructions. I have to
hold the one half in place, fit the other half to it (around the pipe),
then install the hinge pin, then squeeze the halves together and
install the second hinge pin.
Lynn
On Thursday, October 19, 2006, at 12:32 PM, Algate wrote:
Lynn
going to
on my
also
off
Gary Algate
Classic 4 Jab 2200
N369LM |
Lynn Matteson
Posted: Thu Oct 19, 2006 10:15 am Post subject: Kitfox/Jabiru trip numbers |
That explains why I didn't think of it, Michel.: ) I spent a half-day
building some internal baffles, and you guys spent a
half-minute...sheeeesh! A great idea! I can't wait to try it out. I
have installed a (temporary) thermocouple lead into the outlet of each
of my heat muffs, and I can read what the air temp is coming out of the
muffs. I can experiment with different types of baffles and learn what
helps the most....guess that's what makes this "Experimental Aircraft"
experimental.
I wonder what copper scrubbers would do? (please, no plastic scrubbers)
Works for radiators...or it did when they still made them that way, and
the coefficient of heat transmission is better than anything else my
"bible" shows other than silver.
Lynn
On Thursday, October 19, 2006, at 01:03 PM, Michel Verheughe wrote:
in too fast and it didn't had the time to warm up. After adding a SS
and warmer.
... great minds think alike!
Michel
N369LM |
Float Flyr
Posted: Thu Oct 19, 2006 11:59 am Post subject: Kitfox/Jabiru trip numbers |
If you put your scrubber in the heat muff the air will come out slower and
even hotter.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Fri Oct 20, 2006 5:07 am Post subject: Kitfox/Jabiru trip numbers |
Thanks Michel - my mind needs all of the compliments it can get!!!!
Gary
warmer.
Michel
