Cargo pods....
Goto page 1, 2  Next
Aerobatics(at)aol.com
PostPosted: Wed Oct 18, 2006 9:59 am    Post subject: Cargo pods.... Reply with quote
Any leads or ideas for a removable cargo pod that can be used on a KF 2?
I have seen them........
Dave
cliffh(at)outdrs.net
PostPosted: Wed Oct 18, 2006 12:56 pm    Post subject: Cargo pods.... Reply with quote
I just purchased a cargo pod from John McBean
It looks very good except the mounting brackets supplied will not work on my speedster and I will have to make my own.
Floran H.
PostPosted: Wed Oct 18, 2006 1:00 pm    Post subject: Cargo pods.... Reply with quote
In a message dated 10/18/2006 3:58:58 P.M. Central Daylight Time, cliffh(at)outdrs.net writes:
Floran H.
I didn't see anything from their web siteIll call them now..
Dave
Thx guys!
PostPosted: Wed Oct 18, 2006 1:14 pm    Post subject: Cargo pods.... Reply with quote
Hmmmm just called Mcbean
Really nice people.
But they dont have a photo yet... or much info as of yet   does anyone have?
can email it to me at aerobatics(at)aol.com (aerobatics(at)aol.com)
Thx again
Before I commit I would like to know what I am getting involved in as a project...
Dave
KF2
jdmcbean(at)cableone.net
PostPosted: Wed Oct 18, 2006 2:12 pm    Post subject: Cargo pods.... Reply with quote
Floran,
  Please check the bottom of your fuselage.. there should be 4 tabs.. 2 between the lift strut mount points and 2 just forward of those… Those 4 points are where the brackets mount. There should not be an interference with the scoop that is installed on your aircraft.
<![if !supportEmptyParas]> <![endif]>
AUTOTEXTLIST \s "E-mail Signature" <![endif]-->Fly Safe !!
John & Debra McBean
208.337.5111
www.kitfoxaircraft.com
"It's not how Fast... It's how Fun!"
<![endif]--><![if !supportEmptyParas]> <![endif]>
-----Original Message-----
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of floran higgins
Sent: Wednesday, October 18, 2006 2:46 PM
Subject: Re: Cargo pods....
Floran H.
----- Original Message -----
From: Aerobatics(at)aol.com (Aerobatics(at)aol.com)
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Sent: Wednesday, October 18, 2006 11:58 AM
Subject: Cargo pods....
Dave
<![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]>href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matron
Date: 10/18/2006
<![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]> - The Kitfox-List Email Forum - --> http://www.matronics.com/Navigator?Kitfox-List - NEW MATRONICS WEB FORUMS - -->   - NEW MATRONICS LIST WIKI - -->   - List Contribution Web Site - Thank you for your generous support!     -Matt Dralle, List Admin. --> <![if !supportEmptyParas]> <![endif]>
 Filesize:  442.88 KB
 Viewed:  355 Time(s)
flier(at)sbcglobal.net
PostPosted: Wed Oct 18, 2006 4:37 pm    Post subject: Cargo pods.... Reply with quote
Hey John,
The forward 2 attach points are actually eyebolts that go through the floorboards, right? There used to be only the three tabs for the rear bracket that has 3 attach points.
[quote] --
PostPosted: Wed Oct 18, 2006 6:15 pm    Post subject: Cargo pods.... Reply with quote
The two rear tabs are there but the front two are missing. At least they are not visible by looking inside the scoop.
Floran H.
lcfitt(at)sbcglobal.net
PostPosted: Wed Oct 18, 2006 8:48 pm    Post subject: Cargo pods.... Reply with quote
Florin,
My IV has the two between the aft landing gear attach brackets (forfloats, I
think) and a single one forward of that. I don't believe the Model IV had
two forward brackets. I think the forward brackets attached to the floor
board similar to the radiator and shroud.
Lowell
PostPosted: Wed Oct 18, 2006 9:13 pm    Post subject: Cargo pods.... Reply with quote
I think you may be looking too far forward.. There should be 2 between the lift struts and the other 2 are only 12” forward. They should be aft of the radiator not in front of.
John & Debra McBean
208.337.5111
Sent: Wednesday, October 18, 2006 8:15 PM
Floran H.
Sent: Wednesday, October 18, 2006 6:37 PM
Subject: RE: Cargo pods....
Hey John,
From: owner-kitfox-list-server(at)matronics.com (owner-kitfox-list-server(at)matronics.com) [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of jdmcbean
Sent: Wednesday, October 18, 2006 5:12 PM
Floran,
Please check the bottom of your fuselage.. there should be 4 tabs.. 2 between the lift strut mount points and 2 just forward of those... Those 4 points are where the brackets mount. There should not be an interference with the scoop that is installed on your aircraft.
John & Debra McBean
208.337.5111
<![endif]-->
PostPosted: Thu Oct 19, 2006 3:34 am    Post subject: Cargo pods.... Reply with quote
Right Lowell. Florin, do you not have the installation instructions that
details installing the eyebolts? If not, I've got a copy I can email...
Ted
dave
PostPosted: Thu Oct 19, 2006 4:43 am    Post subject: Cargo pods.... Reply with quote
Lowell -- Mine has three only. Did a pod not fit onto the three at one
time?
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
Lynn Matteson
PostPosted: Thu Oct 19, 2006 5:14 am    Post subject: Cargo pods.... Reply with quote
My IV also has just three tabs protruding through the fabric...two aft,
and one forward, which is not on the centerline...I always thought that
was curious. Having not seen the cargo pod, I don't know how this
applies.
Lynn
On Thursday, October 19, 2006, at 12:47 AM, Lowell Fitt wrote:
Florin,
(forfloats, I think) and a single one forward of that. I don't
believe the Model IV had two forward brackets. I think the forward
brackets attached to the floor board similar to the radiator and
shroud.
Lowell
Lynn
Kitfox IV-Jabiru 2200
N369LM
PostPosted: Thu Oct 19, 2006 6:20 am    Post subject: Cargo pods.... Reply with quote
I don't have a cargo pod, but have thought of it from time to time. As I
understand it the pod is supported by two vertical brackets on the back
attached to the tabs and two in front attached to the floor board. The
third tab is for a triangular brace that is attached to the aft weldment for
forward-aft stability.
Lowell
msm_9949(at)yahoo.com
PostPosted: Thu Oct 19, 2006 8:48 am    Post subject: Cargo pods.... Reply with quote
I recall that pod installation instructions are available at the sportflight site (I think). With these instructions and some pictures provided by Don Smythe (?) I was able to fabricate brackets. The 2 front attach points are eye-bolts through the floorboards (just inside and behind control sticks). The 3 rear eyebolts pass through fuse tubes. If you can't find the instructions Dave, contact me off list and I'll send what I have.
flier <flier(at)sbcglobal.net> wrote: [quote] v\:* { BEHAVIOR: url(#default#VML) } o\:* { BEHAVIOR: url(#default#VML) } w\:* { BEHAVIOR: url(#default#VML) } .shape { BEHAVIOR: url(#default#VML) } (at)font-face { font-family: Tahoma; } (at)page Section1 {size: 8.5in 11.0in; margin: 1.0in 1.25in 1.0in 1.25in; mso-header-margin: .5in; mso-footer-margin: .5in; mso-paper-source: 0; } P.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman"; mso-style-parent: ""; mso-pagination: widow-orphan; mso-fareast-font-family: "Times New Roman" } LI.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman"; mso-style-parent: ""; mso-pagination: widow-orphan; mso-fareast-font-family: "Times New Roman" } DIV.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman"; mso-style-parent: ""; mso-pagination: widow-orphan; mso-fareast-font-family: "Times New Roman" } A:link { COLOR: blue; TEXT-DECORATION: underline; text-underline: single } SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline; text-underline: single } A:visited { COLOR: blue; TEXT-DECORATION: underline; text-underline: single } SPAN.MsoHyperlinkFollowed { COLOR: blue; TEXT-DECORATION: underline; text-underline: single } P.MsoAutoSig { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman"; mso-pagination: widow-orphan; mso-fareast-font-family: "Times New Roman" } LI.MsoAutoSig { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman"; mso-pagination: widow-orphan; mso-fareast-font-family: "Times New Roman" } DIV.MsoAutoSig { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman"; mso-pagination: widow-orphan; mso-fareast-font-family: "Times New Roman" } P { FONT-SIZE: 12pt; MARGIN-LEFT: 0in; MARGIN-RIGHT: 0in; FONT-FAMILY: "Times New Roman"; mso-pagination: widow-orphan; mso-fareast-font-family: "Times New Roman"; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto } PRE { FONT-SIZE: 10pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Courier New"; mso-pagination: widow-orphan; mso-fareast-font-family: "Courier New"; tab-stops: 45.8pt 91.6pt 137.4pt 183.2pt 229.0pt 274.8pt 320.6pt 366.4pt 412.2pt 458.0pt 503.8pt 549.6pt 595.4pt 641.2pt 687.0pt 732.8pt } SPAN.EmailStyle19 { COLOR: navy; mso-style-type: personal-reply; mso-ansi-font-size: 10.0pt; mso-ascii-font-family: Arial; mso-hansi-font-family: Arial; mso-bidi-font-family: Arial } DIV.Section1 { page: Section1 } Hey John,
[quote] --
PostPosted: Thu Oct 19, 2006 8:56 am    Post subject: Cargo pods.... Reply with quote
Hey thanks every one... I have a model 2 so it will be a good winter project Smile
PostPosted: Thu Oct 19, 2006 10:37 am    Post subject: Cargo pods.... Reply with quote
I opened up the shroud and didnt see any tabs.
I am planning to make mounting brackets that will attach to the landing gear attachments and brace them to the float attachment brackets.
I possibly will be able to use the rear attachments but will have to brace them to the float brackets also.
Floran H.
FLIER(at)sbcglobal.net
PostPosted: Thu Oct 19, 2006 11:27 am    Post subject: Cargo pods.... Reply with quote
Floran,
Did your pod come with two mounting brackets -- front
with two legs and rear with 3?
I've had a pod on my IV for 5 yrs now and use it
often. Some time ago I took some detail photos for
another gent that was mounting a pod but the attached
is all I could find this morning.
The front mount is simply two AN eyebolts up through
the floorboards just behind the radiator scoop. The
tripod rear mount attaches directly to the tabs on
the tubes.
Ted
attach to the landing =
but will have to =
[quote]brace them to the float brackets also.
Floran H.
 Filesize:  93.58 KB
 Viewed:  312 Time(s)
wingsdown(at)comcast.net
PostPosted: Thu Oct 19, 2006 11:49 am    Post subject: Cargo pods.... Reply with quote
That is very nice. Did you do all the parts or is a plug in play?
Rick
PostPosted: Thu Oct 19, 2006 1:34 pm    Post subject: Cargo pods.... Reply with quote
Thanks. It's the Kitfox standard pod...
<wingsdown(at)comcast.net>
plug in play?
Rick
PostPosted: Thu Oct 19, 2006 6:15 pm    Post subject: Cargo pods.... Reply with quote
The picture you sent look like the mounting brackets that I received from
John McBean
My scoop is different. The rear of the scoop extends back to the rear
mounting bracket on your cargo pod.
It has an adjustable door on the rear that I can adjust from inside the
cabin to control the radiator heat. Just like on a F-51.
Floran H.
Goto page 1, 2  Next
Page 1 of 2
