Aileron Bellcranks
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Tailwind-List
Rcaprd(at)aol.com
PostPosted: Sun Oct 22, 2006 12:28 pm    Post subject: Aileron Bellcranks Reply with quote
Jim C.,
Why did you offset the bellcrank pivots from the slanted supports, for the aileron controls ?
Why did you increase the angle between the arms from 80º to 100º ?
I've got the 100º bellcranks built, and I'm now setting up where the pivot goes.
Chuck G.
NX770CG
- The Matronics Tailwind-List Email Forum -
http://www.matronics.com/Navigator?Tailwind-List
jclement000(at)centurytel
PostPosted: Sun Oct 22, 2006 12:59 pm    Post subject: Aileron Bellcranks Reply with quote
To keep the load on the bellcrank close to the slanted truss. The bellcrank
bushing is longer than the plans bushing to eliminate side play.
100 degree worked out better for the linkage although the 80 degree works
ok. 80 was the stock TW but my mods bellcranks are turned upside down
compared to the originals.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Tailwind-List All times are GMT - 8 Hours
