Battery Question
ByronMFox(at)aol.com
PostPosted: Sun Oct 22, 2006 8:13 pm    Post subject: Battery Question Reply with quote
In September 2005, I put two new Gill G25S 12 volt batteries in my CJ to which I attached a 24 volt battery tender. This past Saturday, I discovered that they were shot after a mere 13 months. I have perhaps been mistaken in believing that keeping batteries fully charged was good practice. Without using a battery tender, the last set a batteries lasted about three years. What is it that I fail to understand --- yet again? Thanks, Blitz
JBernier(at)dart.org
PostPosted: Mon Oct 23, 2006 6:57 am    Post subject: Battery Question Reply with quote
Don't know if I can help, wish Brian was still around. If one battery goes bad on a battery tender, it recognizes a low voltage for both when one is OK and fully charged. It keeps on charging both batteries until both are discovered as bad. The balancer that I put in helps eliminate this problem by draining one battery to replenish the other, even when charging. I use two 12 volt Odyssey batteries in series and draw off one for 12 volts. This has been since April of 05. Both are strong. I'm going to not charge the system with the Battery Tender, while its in the hanger, and see what happens. I'm no expert, just a trial and error guy. I have had a Battery Tender on my boat for 5 years before the 12 volt gel cell battery went bad. And It went TU in one month. From good to nothing.
Jim
>> ByronMFox(at)aol.com 10/22/2006 11:12 PM >>>
